I'm sure this has been covered and is buried somewhere in the forums. What is the best sealant to use for the gaps between vinyl covered plywood floor and stamped metal Gator skinned walls? The gaps vary between 1/8" and 3/8" and movement is certainly inevitable, if only from heat and cold. I will probably not have easy access to cut out and reseal later on in some spots, so not worried about initial cost as much as longevity and keeping any spilled liquids away from plywood edge or getting underneath.
