Old 07-17-2019, 06:56 PM   #11
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Default Re: iCarsoft MB11 Scanner
Originally Posted by dixie265 View Post
I found a adaptor cable that is fully wired for all pins if anyone is looking for one.
https://www.aliexpress.com/item/3294...56484c4dVb1jqK
Lindsay
I received my cable today and so far looks good!
Plugs are screw together style as pictured so will have to do a pin out check against my Autel Benz-CV14.
I'll post later if it checks out.
Keith.
36,000 miles from New
The Following 2 Users Say Thank You to Cheyenne For This Useful Post:
Aussie 2002 4x4 (07-18-2019), dixie265 (07-18-2019)
Old 07-29-2019, 11:30 AM   #12
dixie265
Lindsay
Keith.
Keith,
Did you end up checking out this plug? did it work ?
Lindsay
dixie265 is offline   Reply With Quote
Old 07-29-2019, 11:52 AM   #13
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Hi Lindsay,
Unfortunately it only worked as well as the eBay lead! I could only connect to the CR engine ECU with it.
Pin outs seem very poorly distributed and do not match my Autel Benz CV-14 adaptor. The only pins correctly connected seem to be the Live and grounds and one of the K-lines.
Here is how the pin-outs compare:
Sprinter DLC Function Autel eBay Ali-Express
1 Ground KL31 4,5 4 5
2 Ign On KL15 8 N/C N/C
3 Live KL30 16 16 16
4 Immobiliser 12 15 3
5 Engine rpm 11 N/C 2
6 Central Lock 3 N/C 6
7 Alarm 1 N/C 7
8 SRS/Airbag 6 N/C 8
9 Auto G/Box 15 N/C 9
10 Speed Control 2 N/C 10
11 Add'tl Heating 13 N/C 11
12 IC 7 N/C 12
13 ABS 9 N/C 13
14 CR CDI 14 7 14
When I get time I will try re-soldering the Ali-Express cable to match the Autel adaptor.
At least this is a cheap source of the 14 pin MB plug!
Keith.
And attached as a pdf...
MB 14 Pin to OBD 16 Pin Short.pdf
The Following 3 Users Say Thank You to Cheyenne For This Useful Post:
autostaretx (07-31-2019), dixie265 (07-29-2019), owner (07-29-2019)
Old 07-31-2019, 10:07 PM   #14
autostaretx's Avatar
... and as an image: (1st column: 14-pin circular, rest of columns: 16-pin OBD socket)
The Following 4 Users Say Thank You to autostaretx For This Useful Post:
Cheyenne (07-31-2019), dixie265 (08-01-2019), MEAT_WAGON (08-01-2019), owner (08-01-2019)
Old 08-31-2019, 10:20 AM   #15
MEAT_WAGON
Iím having the same problem.. Iíve got 3 different plugs and they are all reading bugger all on the 2003
MEAT_WAGON is offline   Reply With Quote
Old 08-31-2019, 10:25 AM   #16
dixie265
Lindsay
Yes , I've given up...I think the Aust T1N is not OBD2 as the US ones are so don't think you will get much out of them unless you use the Merc Star program.
Lindsay
Old 08-31-2019, 10:29 AM   #17
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
I would imagine your Aus Sprinter is the same as my UK model, a round 14 pin twist lock connector.
I use an Autel MD802 with the genuine Autel Benx CV-14 adaptor and this can access all my modules (only 4 as no ABS, A/C, alarm, etc).
The 14 pin connector is definitely not OBD compliant!
There is a thread under the scanners sub-forum about the 14 pin DLC.
https://sprinter-source.com/forum/sh...ad.php?t=77817
Keith.
The Following User Says Thank You to Cheyenne For This Useful Post:
dixie265 (08-31-2019)
Old 09-01-2019, 02:24 PM   #18
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
I have just updated my other thread stating that I have successfully rewired the Ali-Express cable and it now allows access to the four modules on my T1N, see link in post above.
Keith.
MEAT_WAGON (09-02-2019)
Old 09-02-2019, 04:55 AM   #19
PeterInSa
So Keith you have rewired pins 1-5 to line up with the Sprinter DLC configuration but I don't have your Autel MD802 scanner just one from ebay ( maybe even Ali Express) Whats the chance of it working
PeterInSa is online now   Reply With Quote
