Batilzown Datacard
2003 2500 Fraightliner
172 FUEL PREHEATER
5524 No code designation available
580 No code designation available
936K No code designation available
AC6 AXLE RATIO I = 3.727
BB0 BRAKING SYSTEM WITH ABS/ASR OR ABS/ETS
C38 REAR SPRING FOR WEIGHT VARIANT 3,880 KG
C42 STABILIZER,REAR AXLE UNDER THE FRAME
C45 H.D. FRONT AXLE STABILIZER
C47 H.D. SHOCK ABSORBERS
D50 PARTITION PANEL FULL-WIDTH
E58 ELECTRICAL COMPONENTS FOR NAFTA TRAILER SOCKET
E88 CIGAR LIGHTER
EE8 12V BATTERY 100 AH
EF7 RADIO SOUND 30 W. SINGLE CD PLAYER AND 2 SPEAKERS
EK1 TERMINAL STRIP FOR ELECTRICAL CONNECTION
ES5 12V POWER SOCKET, INSTRUMENT PANEL
F68 HEATED AND ELECTRICALLY ADJUSTABLE OUTSIDE MIRROR
F76 GRAB HANDLE CO-DRIVER SIDE
FG7 STORAGE BOX AT CO-DRIVER SEAT
FG8 CUP HOLDER(S), FRONT
FY6 CENTRAL LOCKING WITH RADIO REMOTE CONTROL NAFTA
G40 AUTOMATIC TRANSMISSION
H01 HEAT INSULATION CARGO AREA/PASSENGER COMPARTMENT
H04 HEAT INSULATION DRIVER CAB
H12 HOT WATER ADDITIONAL HEATER
Identification number: WD290366215534161 X VIN: WD2YD642235534161
Copyright Daimler AG , 1/8/16 12:14 AM , EPC 2.2.1.0 DW 01/2016 , User: uie06119 Page: 3
H15 SEAT HEATER FOR FRONT PASSENGER
H16 SEAT HEATER FOR DRIVER
H21 ALL-RND.HEAT ABSORB.GL.W.BAND FLTR ON FR.WINDOW
H86 TIMER FOR HEATER BOOSTER
HH9 SEMI-AUTOMATICALLY CONTROLLED TEMPMATIC A/C
HZ9 HEATER BOOSTER, DIESEL
IL2 EXPORT CODE
J11 SPEEDOMETER MPH AND KM/H
J61 HYDRAULIC BRAKE TEST CONNECTION
J65 OUTSIDE TEMPERATURE INDICATOR
JW0 BACKUP WARNING SYSTEM
KB0 MAIN TANK 100 LITER
KL1 FUEL-LEVEL SENSOR FOR AUXILIARY HEATER
KL5 FUEL FILTER WITH WATER SEPARATOR
L05 AUTOMATIC DAYTIME RUNNING LIGHTS FOR USA/CANADA
L62 READING LAMP
L65 COURT. LIGHTS F. TRUNK/PASS. COMP. W. DOOR CONT.
LB5 CENTER HIGH-MOUNTED BRAKE LAMP
M96 FUEL PREHEATER
MF1 LOW-EMISSION ENGINE AS PER CFFP (NAFTA)
MQ6 ENGINE OM612 DE27 LA 115KW (156HP) 3800RPM
MS1 TEMPOMAT (CRUISE CONTROL)
P47 MUDFLAP FRONT
P48 REAR MUD FLAPS
Q24 NAFTA TRAILER CROSSMEMBER, TOWING CAPACITY 5000LBS
R65 SPARE WHEEL CARRIER UNDER FRAME END
R87 SPARE WHEEL
RA5 DROP CENTER RIMS 6 J X 16 H2 F. 225/75 R16
RF8 TIRE MANUFACTURER MICHELIN (80)
RG8 TYRES 225/75 R16
RM0 ALL-SEASON TIRE
RM9 TIRE MAKE SPECIAL REQUEST
S22 DRIVER'S SEAT ARMREST
S25 CO-DRIVER'S SEAT ARMREST
SA5 AIRBAG DRIVER SIDE
SA6 CO-DRIVER'S AIR BAG
SB1 DRIVER SEAT, COMFORT
SB2 PASSENGER SEAT, COMFORT
SS1 VENICE SEAT COVER FABRIC
T16 SLIDING DOOR RIGHT
T85 ENTRANCE GRAB AT CORNER PILLAR AT LEFT REAR
T86 ENTRANCE GRAB AT CORNER PILLAR AT RIGHT REAR
Copyright Daimler AG , 1/8/16 12:14 AM , EPC 2.2.1.0 DW 01/2016 , User: uie06119 Page: 4
V43 WOOD FLOOR
V50 ELECTRIC WINDOW LIFTER, 2-WAY
VA3 LOAD COMPARTMENT INNER TRIM UP TO ROOF WASHABLE
W54 REAR-END DOORS, DOUBLE-WING, OPENING TO SIDE WALL
X42 PLATES / PRINTED MATERIALS ENGLISH
X92 COMPANY LOGO (MERCEDES-BENZ) DELETED
XL8 WEIGHT VARIANT 3880 KG
XY3 MODEL YEAR 3
Y11 BRACKETS USED FOR WARNING TRIANGLE
Y17 PRE-FITTINGS FOR FIRE EXTINGUISHER
Y43 HYDRAULIC JACK
Z41 APPROVAL AS TRUCK
Z75 BODYSHELL REINFORCEMENT
Z81 TIE-DOWN EYES
Z90 UNDERBODY CONSERVATION DELETED
ZB6 PRODUCTION PARTS KIT
ZU8 USA COUNTRY VERSION
ZX8 DODGE EXECUTION
