My Sprinter's A Lemon
What might be the reason my key only goes half way into the rear cargo door lock? It won't go in far enough to engage so I am unable to unlock/lock the door.
Thanks.
Thanks.
Thanks for the responses. Lubing didn't work. ...
I let it soak over a couple weeks, but now you're down a different rabbit hole.... It took some time soaking with WD40 applied using the red straw to free things up. I never needed to disassemble anything.
That's true about the ignition switch, i don't know about the door handles.It appears that you can't "unclip" the cylinder to take it out without the key inserted. Am I correct?
The cylinder would have been removable BUT you appear to have something like a broken key in yours so hence it now cannot be removed.I took the lock to the locksmith, Serrupro. They told me today that they can't get the cylinder out without breaking the rest of the lock.
Dodge wouldn't put in a cylinder that couldn't be taken out. So what's the deal?
