Rider/Writer
I recently took delivery of a new 08 Pleasureway Excell. We like everything about this RV, except for one big problem. At any speed over 45 mph the front end oversteers so bad that I can barely keep it on the road. I checked the tire pressure and found it to be 50 front and 70 rear. I increased it to 55 front and 80 rear with slightly better results, but it still is hard to control as speed increases to 55 mph. The tires are in ballance and the alignment is good. It is a brand new RV. Is this normal? I should be able to at least drive it at 65 mph, or am I wrong? Has anyone else had this problem, and if so, what did you do to correct it.
Thanks,
An Unhappy Camper
Thanks,
An Unhappy Camper
