Old 02-16-2015, 05:28 AM   #11
Onefin
Default Re: Mojovan Promaster
Mojogoat: thanks for the responses.
I will check the promaster forum as well.
I have begun seeing lots of promasters around where I live.
Old 02-18-2015, 08:27 PM   #12
mojogoat
Installed marine shore power inlet with 10/3 wiring, mfg roof brace to stop roof sagging bouncing from A/C.
http://s1276.photobucket.com/user/mc...ibrary/Mojovan
mojogoat is offline   Reply With Quote
The Following User Says Thank You to mojogoat For This Useful Post:
slem (02-23-2015)
Old 02-26-2015, 04:58 PM   #13
mojogoat
Default Progress pics
Roof beam, 1 1/2" thick floor mat, tv inlet, lithium batteries.
http://s1276.photobucket.com/user/mc.../Mojovan/story
Old 02-26-2015, 05:10 PM   #14
surlyoldbill
surlyoldbill's Avatar
I just took a tour of the ProMaster at a local Dodge dealer (picking up rear pinion seal part).
Interior is great, I like the dash layout and the interior width, and the cubbies above the driver.
Still can't get over the low rear drop axle, so I won't be getting one.
One thing I didn't think of until the salesman pointed it out, if you have the diesel with the elec. manual tranny, you need to remember to put on the parking brake when you get out! He said that's why they put it on the outside, so if you start getting out and the van starts rolling you can reach it through the open door.
Former owner of Surly Mobile:
Old 02-26-2015, 05:23 PM   #15
mojogoat
How much higher is the bottom of the Differential on a sprinter?
Old 02-26-2015, 08:24 PM   #16
35603
I own a diesel Promaster and I can assure you that the salesman is misleading you.
When I shutdown the Promaster I leave it in gear just like any manual transmission vehicle. There is no "park" position like a conventional auto tranny vehicle. At that point you can apply the parking brake or not. If left in gear the Promaster will not roll.
35603 is offline   Reply With Quote
Old 02-26-2015, 10:57 PM   #17
surlyoldbill
I think he said if it was out of gear. I was taught to only park in neutral with manual trannys, I don't know why.
Old 02-26-2015, 11:05 PM   #18
surlyoldbill
I measured mine at almost 9". But the differential doesn't span the entire width like the drop axle does. My Sprinter shock mounts are around 10". There is only a short space between, maybe 12-15", that has a clearance of 12" or more, so it could be argued that the extra clearance isn't as effective as it would seem.
I still think that there will be a revision in a year or two, maybe just for the American market, that will flip the axle and hang the shocks from it instead of putting them on top like they do now. Or there will be an aftermarket kit to do that. A few incidents of people tearing out their rear axles will inspire the change.
Old 02-27-2015, 01:08 AM   #19
jostalli
The Fiat Ducato is the top selling cargo van world wide. We only just received the model that everyone else has had for years. If the design caused "incidents of people tearing out their rear axles" then I'm sure it would have been changed long ago.
There is no reason to be worried about the design. I have said this before that I have no problem taking my Promaster off road through Baja (which is happening starting in August).
jostalli is offline   Reply With Quote
Old 02-27-2015, 02:26 AM   #20
surlyoldbill
It freaks me out, man!
I'm sure you're right, I took my little Fiat 128 on crazy jeep trails and often just straight through the woods, and it had even lower ground clearance. And neither the Transit, Sprinter or Promaster were designed to go on off-pavement adventures, and I doubt more than 1% ever will. I'm sure I could manage a RamMaster on nearly all the places I've been in my Sprinter, but that extra bit of clearance provides a little more confidence.
Hey, since it's FWD, and most opportunities to hit the drop axle would occur at crawling speed, an angled guard in front of the drop axle to ramp it up and over the rock/stump/body/etc might be pretty handy. And a profitable little aftermarket product for a fabricator!
