Old 08-10-2019, 06:06 PM   #1
henry9
Default AGMís affected by engine heat?
Hi,
Iíve got the old school lead acid batteries that Iím considering replacing with AGMís due to the corrosive effects to the nearby brake lines. I know Roadtrek switched to AGMís but do they degrade faster due to engine heat? Just wondering, definitely going to replace with seals AGMís!
2008 Agile
Henry
henry9 is offline   Reply With Quote
Old 08-10-2019, 06:13 PM   #2
jdpartin
Default Re: AGMís affected by engine heat?
Underwood might be a minor problem in traffic jams but usually you cruise along at 70 or so and engine heat is being blown away. What killed mine was extreme cold of 10-15 degrees or so for a week.
jdpartin is offline   Reply With Quote
Old 08-10-2019, 06:49 PM   #3
There's another recent thread where someone put a layer of Reflectix around his under-hood AGM .. and it made a 20 F difference in their temperature
(i'll add a link if i find it)((done two posts down v))
Old 08-10-2019, 07:06 PM   #4
Rock Doc
I don’t know if AGMs degrade faster with heat than FLAs, but it’s true that heat isn’t a friend to ANY battery system or chemistry.
I think the reality is that we face a series of compromises with our battery systems and chemistries that at best, we can optimize, but not make perfect. The factors I see are costs, location, safety, and the effort/work/time that must be accommodated to change a given configuration. It’s all a type of iron triangle where you can’t make the system perfect, so you choose which are the most important factors for your situation, and then allow yourself to be satisfied with that.
Don’t let the perfect be the enemy of the good!
(For me, my two GC1 FLA batteries are under the hood, and I have Reflectix around them to give some heat shielding.)
Rock Doc
2014 Pleasureway Plateau TS in 2013 Sprinter 3500
Rock Doc is offline   Reply With Quote
Old 08-10-2019, 07:17 PM   #5
RockDoc's thread: https://sprinter-source.com/forum/sh...ad.php?t=78407
Inspector (08-13-2019)
Old 08-10-2019, 08:19 PM   #6
GeorgeRa
2013 Sprinter DIY 144WB
GeorgeRa's Avatar
I have 115Ah AGM Fullriver under the hood since 2013 coupled with one in the van. Didnít noticed battery degrading. Battery is well insulated.
It is certainly not the best scenario but it was a reasonable tradeoff due to space limitation.
George.
Old 08-11-2019, 06:10 PM   #7
henry9
Thanks everyone for info. Much appreciated!
Old 08-13-2019, 06:21 PM   #8
RT.SS
Not sure if how much degradation if any, but itís most likely not good for the battery when exposed to extreme engine heat, not to mention the ill effects of constant higher charging voltage (14+) from alternator when battery is hot. I fabricated a battery enclosure on mine using aluminum sheet lined with heat insulation mat, the batteries temp stays below 90ļF (per Blue Sky/ and Magnum battery temp monitor) even after long drives.
Picture with the front heat shield removed.
