Go Back   Sprinter-Forum > Classifieds > For Sale (Sprinter vans Only)
For Sale (Sprinter vans Only) Post Sprinter Vans for sale here. Vans must be driveable, otherwise, they go to the parts section here.
Old 04-26-2018, 09:00 PM   #1
Neil2
Neil
Neil2's Avatar
Default 2007 Dodge Super High Passenger Sprinter
LOW miles. LOADED with options! 2nd owner selling to downsize. 59k miles (~5k/year!) and >37k are highway miles. Original owner's manuals included. No seating or mounts included. No troublesome DEF system! Pictures, videos and owner documentation are available. Bessie is a beauty, has many very sought after options, some of which I treasure are: heated everything, TWO D5 Espar Furnaces, rain sensors, cruise, and suspension seats. Everyone thinks she's younger than her years. DPF is in great shape. I've invested >$16k in maintenance, upgrades and conversion. She's ready for you to build to suit. The subfloor (for batteries) may be removed in minutes. Bessie has more options than any owner operated Sprinter I've seen. FIRM price: $30,000.
CHASSIS
144" wheelbase, V6 Turbo Diesel Engine, 5-speed automatic transmission with (Tip Shift) manual control for towing/heavy loads, Four 12V Auxiliary power outlets, Interior motion sensor alarm
MAINTENANCE
2017 Replaced 4 Glow plugs, Upgraded glow plug module, Temperature sensor, 4 Michelin tires, 2 Fuel injectors, Sway bar bushings
2018 Replace & Reroute rear tailpipe, 3 Fuel injectors, EGR valve and Fuel filter
2019 'A' Service, Remove & replace: Rear axle fluid, Engine oil/filter, Transmission fluid, Cabin & Engine air filters, Tie rods/ends & Alignment, Wye harness (Alternator/Starter/Battery), 3 Fuel injectors, Fuel filter, 1 Bridgestone tire
UPGRADES
2017 Formula1 Pinnacle cockpit & rear window tint, Enerlogic35 cabin side window tint (Rejects 79% of solar.), Ceiling fully insulated (R9.4) with R-max (Poly-Isocyanurate) rigid panels and foam (The most effective insulation on the market http://en.wikipedia.org/wiki/R-value_(insulation), 3 Van Specialties ceiling cabinets (Burnt Strand- Formica) Custom, professional built 1/2" steel hitch step with non-skid and lock
, Phifer 95% screen installed behind cockpit for privacy while providing exterior views, MaxxAir Ceiling fan with remote, LED Engine Battery Voltage Meter, Custom Poly-Isocyanurate cabin insulating window boards
2018 Llumar Air80 Windscreen Film (Rejects 43% of solar.), Custom, Magnetic, Insulated window covers (cockpit, rear and slider) allow 100% privacy, Rear shocks (Koni Reds), Hellwig sway bar & OEM AGM Engine & Auxiliary Battery & Tray
2019 New Furnace Remote, Cockpit Shelf, MB Hubcaps & Rear badge, Fatmat Sound Deadener (Rear deck and wheel wells)
OPTIONS (PARTIAL)
C01 Driver Comfort Package: $575
C03 Active Safety Plus Package: $1,905
CL4 Multifunction steering wheel with trip meter
CT1 Rear Spring Vibration Absorbers $128
D13 - MOUNTING RAILS FOR ROOF RACK $277
E40 - TRAILER PLUG SOCKET, 7-POLE
E46 12v Power Outlet- Driver Seat Base
EP5 - CD CHANGER
ED5 Parametric Special Module $293
EN7 Audio 15 (Standard)
ES2 12V Power Outlet Rear Compartment $85
F46 - HEADLAMP WIPER/WASHER
F49 - WINDSHIELD HEATED
F66 - LOCKABLE GLOVE COMPARTMENT
F68 - HEATED & ELECTRICALLY ADJUSTABLE SIDE MIRRORS
FF8 Overhead storage slot, front center $97
FJ1 I/P Hinged Lid-Center Stack Bin
FY1 - THEFT PROTECTION PACKAGE: $625
FY7 3-Button Remote Control $33
FZ9 - TWO ADDITIONAL MASTER KEYS
H00 - HOT/COLD AIR DUCT TO PASSENGER COMPARTMENT
H01 - HEAT INSULATION CARGO AREA/PASSENGER COMPARTMENT
H04 - HEAT INSULATION DRIVER CAB
H13 - ADDITIONAL HEAT EXCHANGER, REAR
H15 - SEAT HEATER FOR FRONT PASSENGER
H16 - SEAT HEATER FOR DRIVER
H21 - ALL-ROUND HEAT ABSORBING GLASS WITH BAND FILTER ON WINDSCREEN
H22 - HEATED REAR WINDOWS
HH2 - ELECTRICALLY POWERED HOT-AIR AUXILIARY HEATER
HY1 - RADIO REMOTE CONTROL FOR AUXILIARY WATER HEATER
HZ5 - HOT WATER AUXILIARY HEATER WITH TIMER SWITCH 10kw
IL6 - METALLIC FINISH
J11 - SPEEDOMETER mph & kmh
JA5 - LIGHT & RAIN SENSOR
JA6 Collision Prevention Assist
JW0 - BACKUP WARNING SYSTEM
KL1 - FUEL-LEVEL SENSOR FOR AUXILIARY HEATER
L16 - HALOGEN FOG LAMPS $224
LA1 High Beam Assist
LB9 Illuminated Exits $139
LD0 - OVERHEAD CONTROL PANEL WITH 2 READING SPOTLIGHTS
LD4 - CONVENIENCE LIGHTING IN LOAD/PASSENGER COMPARTMENT
LG0 - BI-XENON HEADLAMPS
M46 - 14v/220a ALTERNATOR
ME8 - LOW EMISSION ENGINE EPA 07/CARB
MP0 - ENGINE OM642 DE30 LA115 KW (156 HP) 3800 rpm
MS1 - TEMPOMAT (CRUISE CONTROL) $378
Q24 - NAFTA TRAILER CROSSMEMBER, TOWING CAPACITY 5000lbs
X22 Trailer Hitch Crossmember & Prep Package: $375
RL5 - 6.5Jx16 LIGHT ALLOY WHEELS
RY2 - TIRE PRESSURE MONITORING AT FA & RA, WIRELESS
S87 - DRIVER SEAT FRAME, LOW
S88 - FRONT PASSENGER SEAT FRAME, LOW
SA5 - AIRBAG DRIVER SIDE
SA6 - PASSENGER AIR BAG
SB3 - DRIVER SEAT SUSPENSION SEAT
SB4 - PASSENGER SEAT SUSPENSION SEAT
SH7 - THORAX SIDE AIRBAG FRONT DRIVER & FRONT PASSENGER (IN BACKREST)
SH9 - WINDOWBAGS FOR DRIVER AND FRONT PASSENGER
SK0 - DRIVER COMFORT HEAD RESTRAINT
SK1 - PASSENGER COMFORT HEAD RESTRAINT
T75 Door mounted assist handles, driver & passenger
T85 Assist Handle- Left Rear Door $29
T86 Assist Handle- Right Rear Door $29
V64 - ASHTRAY IN PASSENGER COMPARTMENT
V85 - SMOKER PACKAGE
VA7 - STOWAGE COMPARTMENT WITH NET IN REAR DOORS
VG1 - ART GRAY BRASAO FABRIC
W70 - COLOR GLAZING IN REAR GLASS
W78 - REAR DOOR WINDOWS WITH WIPER & WASHER SYSTEM (Removed)
XL8 - WEIGHT VARIANT 3880kg
XWAP - First Aid Kit
XDPP - Road Hazard Warning Lamp
X13 Lighting Package: Bi-xenon headlamps with washers $960
Y43 - HYDRAULIC JACK
9154 - PAINT, CHARCOAL BLACK METALLIC MB9154
[FONT="Comic Sans MS"]Neil
2007 2500 SH Passenger 144" Sprinter (Bessie)
Neil2 is offline   Reply With Quote
Old 04-26-2018, 09:31 PM   #2
mfc
Default Re: 2007 Dodge Super High Passenger Sprinter
where are you located I have a 85 vanagon camper to sell so I can ujse money towards sprinter I'm in n California
mfc is offline   Reply With Quote
Old 04-26-2018, 10:24 PM   #3
dixon
would love to see some photos, videos...
dixon is offline   Reply With Quote
Old 04-26-2018, 11:03 PM   #4
Wallygirl
Wallygirl's Avatar
Hi. Yeah where are you located? Are the airbags new? All 2007 were Takata and under recall. I know because I replaced them on my 2007. Why Westphalia?
Wallygirl is offline   Reply With Quote
Old 04-27-2018, 12:38 AM   #5
Neil2
Neil
Neil2's Avatar
It's on my handle. I'm due North of you.
Old 04-27-2018, 12:41 AM   #6
Neil2
Neil
Neil2's Avatar
I've posted some pics. Let me know if you want more, or videos or docs.
Old 04-27-2018, 03:49 AM   #7
mfc
I see Portland what vw are you looking for
Old 04-28-2018, 11:56 PM   #8
Neil2
Neil
Neil2's Avatar
The airbags were replaced under the recall notice, long, long ago.
Old 05-07-2018, 09:02 PM   #9
Neil2
Neil
Neil2's Avatar
Bump! Bessie's back in Oregon for a couple of months!
Old 05-08-2018, 04:39 AM   #10
rr4goose
I don’t know what pm addy means. I’m in McMinnville, Oregon and am interested.
rr4goose is offline   Reply With Quote
