Old 08-17-2019, 07:11 PM   #1
mrcolin2u
2005 Sprinter
Default Help ! Do I have the wrong belt ?
Iím replacing idler pulleys and tensioner and the belt.
Iím trying to get the new belt on but it is very tight
Iím wondering if this is the wrong belt for my 2005 T2N ?
Does anyone know here ?
File Type: jpg 5E3D393F-2A2D-49D3-A9C1-999F4E45802C.jpg (95.6 KB, 51 views)
mrcolin2u is offline   Reply With Quote
Old 08-17-2019, 07:50 PM   #2
Default Re: Help ! Do I have the wrong belt ?
After checking these threads, please post what you decided. 2260 is ideal. 2257 is apparently an often sold replacement. 2257 in conjunction with a larger diameter 70 replacememt idler pulley is even more of a dilemma.
https://sprinter-source.com/forum/sh...ight=2257+2260
https://sprinter-source.com/forum/sh...4&postcount=33
Old 08-17-2019, 07:59 PM   #3
Looks like you bought the Europarts-SD.com kit which comes with a 2257 serpentine belt (for some reason, they don't sell a 2260). You're in good company as lots of folks have apparently bought this kit from them.
If you ordered the kit version with a smooth pulley and not a later ribbed version pulley, you'd probably be even better off, while best off would be a smooth pulley and a 2260.
For peace of mind, you could just buy another 2260 from Eurocampers.com for $26.87 or elsewhere, and keep the 2257 as an emergency spare (good idea to have a spare).
http://www.eurocampers.com/2001--200...oses_c_99.html
Please post what you decide. Also, please post any tips (the DIY threads on opening the radiator stack like a door for access and other write-ups are helpful).
mrcolin2u (08-17-2019)
Old 08-17-2019, 09:31 PM   #4
mrcolin2u
2005 Sprinter
I put the old belt back on and I've asked Europarts SD to send me a 2260. If they don't send me one I'll get one from somewhere else. I prefer to replace the same part # I took off when possible , besides that the 2257 is tight and I was struggling to get it on, in fact I gave up after I double checked the part number.
I replaced both idler pulleys and the tensioner. The new INA pulleys look the same size as the original OEM , one ribbed one smooth.
I tilted the radiator forward without disconnecting any pipes and used a piece of wood to prop it forward.
I removed the viscous fan with an 8mm allen wrench and kept the water pump from spinning by using a bastard file wedged beset the small bolt heads on the water pump pulley.
With the fan removed I had plenty room to get my fat hands in and replace the parts .
I kept the viscous fan upright and cleaned the fan blades and clutch with a solvent spray.
Replaced everything in reverse order and torqued to specs as well as using blue lock tight on the threads .
The idler pulleys felt like they spun a bit too easy like there was no grease in the bearings . The tensioner didn't feel too bad and I almost was going to leave it in but I decided to replace it anyway just because I already had easy access.
I'm disappointed with the V-belt , I'm going on a trip next 6 days and expect to do 600 or 700 miles. The original belt doesn't look too bad but it would have been nice to have it changed today with all the stuff out the way.
Wish I'd known about what exactly was in that kit before I ordered !
Old 08-17-2019, 09:35 PM   #5
Patrick of M
2005 T1N 2500 (NA spec)
What do you mean by very tight? If the tensioner still has room.to move in both directions you will be fine. The belt will also stretch a leetle bit as it gets used.
Patrick of Montreal
2005 T1N (NA spec).
Patrick of M is online now   Reply With Quote
Old 08-17-2019, 10:46 PM   #6
mrcolin2u
2005 Sprinter
It was so tight I was struggling to get it on. The old belt was easy.
Old 08-18-2019, 01:42 AM   #7
My guess would be that you had the new belt incorrectly routed when you tried to install the 6PK2257 belt or the belt wasn't properly seated into one of the grooved pulleys. What you describe is exactly the scenario when the belt is incorrectly routed. Don't ask.
I have installed both a 6PK2257 and a 6PK2260 belt and either installs just fine when the belt is correctly routed. Either length belt works fine on my 2004 and 2006 in my experience.
Old 08-18-2019, 02:15 AM   #8
Patrick of M
Like I said, once on as long as the tensioner has play you r good. This of course presumes u routed it correctly. Does it match the diagram you made on the windshield washer tank with a sharpie?
Patrick of Montreal
2005 T1N (NA spec).
Old 08-18-2019, 02:44 AM   #9
mrcolin2u
2005 Sprinter
You hit the nail on the head Vic, the belt was incorrectly routed initially. It still felt a bit tight even though I was giving the tensioner some slack. I think I'll try again after my trip , I'm still trying to organize my stuff for camping tomorrow for 6 nights and I'm knackered
Old 08-18-2019, 02:49 AM   #10
mrcolin2u
2005 Sprinter
I have a picture on my phone of the correct routing which I didn't refer to initially and made a mistake
I did try with the correct routing though and it felt too tight even though the tensioner was fully off !
I'll give it another go later , I think I just got tired and convinced myself that the 2257 was the wrong size ! I know earlier in the week I took the old belt off and put it back on again and it was a piece of cake ! I was expecting the same with the new belt but it wasn't to be.
