Old 08-17-2019, 01:24 AM   #1
Coolio
Default So...my hood wont open?
So the openhood latch under the dash is not engaging with hood unlocking mechanism in the engine compartment. Have no idea why and trying to figure this out without braking something. Anybody ever have this happen to them? cheers
Coolio is offline   Reply With Quote
Old 08-17-2019, 02:11 AM   #2
Carminooch615
Carminooch615's Avatar
Default Re: So...my hood wont open?
Have someone press down on your hood as you go inside the cab and pull the latch again. This is the only way I can do it lately. While itís open, hit it with some white lithium grease or something
Northern NJ / Benevento Italy
2018 Chevy Cruze hatchback RS. Diesel and 6spd manual.
2006 Dodge Sprinter 2500, 140" - 160,000 miles
1999 Jeep Wrangler - diesel swapped OM617 3" lift, 35" tires, 20mpg
Carminooch615 is offline   Reply With Quote
The Following User Says Thank You to Carminooch615 For This Useful Post:
Coolio (08-17-2019)
Old 08-17-2019, 02:32 AM   #3
Coolio
I was able to get my grill cover off and then push on the release from the bottom with a screw driver. Just seems sticky and maybe a new cable would help. wack.
Old 08-17-2019, 02:37 AM   #4
SkyGypsy
Spray it liberally with wd40. Helped a ton for me. If that doesn't work get a cable lubricator. I doubt you need a new cable.
2005 158 high roof 200k or so
SkyGypsy is offline   Reply With Quote
Old 08-17-2019, 11:25 AM   #5
hkpierce
'02 140 Hi BlueBlk Pass
Several ideas here: https://sprinter-source.com/forum/sh...highlight=hood
Old 08-17-2019, 01:06 PM   #6
Patrick of M
2005 T1N 2500 (NA spec)
WD is a good start for loosening but it doesnít leave enough lube behind. After the WD follow up with silicone spray or some other lubricant that will stay around.
Patrick of Montreal
2005 T1N (NA spec).
Old 08-17-2019, 02:11 PM   #7
Check for the pin showing wear.
An old thread.
Over time my 2004 hood latch cable became harder and harder to pull to the point that I worried about something breaking. I routinely lube those and other parts. Extra lube didn't help. Inspection showed that the pin had a worn flat spot. I rotated the pin 1/2 turn looser and everything went back to working properly.
My guess is getting off the flat spot was more help than was the 1/2 turn looser.
