Go Back   Sprinter-Forum > Sprinter-Based RV's & Conversions > Sprinter-Based RV Brands > Gulf Stream > Vista Cruiser MB
Old 10-01-2019, 07:38 PM   #1
Dirk
Default 2005 G24, whereís my converter??
Hi All, New here. Picked up my G24 a few months ago on Craigslist. Iím having a blast but I mainly Boondock visiting my kids/grandkids. The A/C was taken off and a 3 panel solar panel system was added. Everything works except for the Micro and a few outlets without shore power. Iím trying to run the Micro off the inverter but I canít find the converter to unplug it. Manual says under the frig but thereís only a fuse panel and I donít see it back cabinet. Past owner craigslists email is expired. Thought I ask the experts here. Iím thinking maybe I should just take out and unplug the micro and run it to the inverter.
Thanks
D~
Dirk is offline   Reply With Quote
Old 10-03-2019, 02:50 AM   #2
Saturn949
Default Re: 2005 G24, whereís my converter??
As far as I know factory do not installed 12v to 110v AC inverter.
In manuals you may see device called converter and this is simply a 12v Lead acid battery charger and 12v source for on board 12v systems as light pumps and fans.
By design Onan generator must be running for microwave use. Or you have to be on shore power. Power selection relay located in water pump compartment under bed from left.
Saturn949 is offline   Reply With Quote
Old 10-04-2019, 06:00 PM   #3
Dirk
Thank you, that makes more sense.
my generator does not run and I donít see a need to fix it with the solar and no ac.
The power selection relay I think is what Iím looking for.
If I want to run my solar inverter in, like shore or gen power it sounds like with the gen down I should just disconnect the gen wire and hook the solar inverter and select it on the relay.
Does that sound correct? Iím more mechanical than electrical
Thank you
D~
Old 10-05-2019, 03:09 PM   #4
Smbrick
Mine has a converter (house battery charger) in the passenger side compartment under the bed, where the house battery is. It looks factory.
2006 Frieghtliner 2500 158" Hi-top - Gulf Stream Vista Cruiser MB
Smbrick is offline   Reply With Quote
