Old 01-20-2019, 10:05 PM   #1
Default DIY Alignment tools.
Anyone have experience with these DIY alignment tools?
https://amzn.to/2W13zbz
Only good for a 2 wheel alignment, but that's all the sprinter needs usually. 210$ is not much more than a 2-3 alignments (or 1 at the dealer!).
A level surface is needed, but for slight off-level driveways, you can measure the ground and adjust your camber reading accordingly. I am thinking I might pick one up.
One caveat is that sidewalls taller than 7.5" would require a riser block under the jig to measure toe.
Old 01-20-2019, 10:36 PM   #2
The Grand Tour
Banned
Default Re: DIY Alignment tools.
I've done my own alignments on race cars for many many years. The quality of alignments, more so than a lot of other things, comes down to the skill of the person performing them more than anything. If you are good at it (and I am) and are a perfectionist (and I am), then the results can be very good.
Old 02-11-2020, 12:21 PM   #3
Well I ended up ordering one for the 4x4 conversion setup. Should give it a go this weekend.
Bobnoxious (02-11-2020), Cwhite87 (02-17-2020)
Old 02-17-2020, 01:58 PM   #4
Used the tool on saturday. Its a bit fiddly to get setup the first time. I think gluing some small magnets to the contact points (for steel wheels) would be helpful. For tires larger than 265/70 you may need a pair of wood blocks to elevate the the plates enough to make contact with the wheel. Otherwise it worked fine, and I had no issue getting the toe plus/minus 1/32" in a few minutes.
The Following 4 Users Say Thank You to Midwestdrifter For This Useful Post:
BrennWagon (02-17-2020), gilee (02-18-2020), Sidecar (02-17-2020), Zundfolge (02-18-2020)
