Go Back   Sprinter-Forum > General Forums > Sprinter Talk > Scanners
Old 01-05-2019, 08:44 PM   #1
damien89
Default Anyone managed to connect a scan gauge to 16+ sprinter?
Tried connecting mine to my 17 euro spec sprinter but unfortunately stays in the connecting screen and then shuts off. Anyone experience this?
2017 Sprinter 516cdi OM 651 7G-Tronic LWB 'LongTail'
damien89 is offline   Reply With Quote
Old 01-05-2019, 11:33 PM   #2
Default Re: Anyone managed to connect a scan gauge to 16+ sprinter?
In another thread someone quoted the LinearLogic troubleshooting information.
Primarily it was "manually set the communication protocol" instead of leaving it to snoop it out on its own.
No one reported "results" of that hint ... so use the buttons to get to the appropriate SETUP screen, and try the different protocols.
And then please report back.
Old 01-06-2019, 09:26 AM   #3
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Correct Dick,
It was me replying to Damien following on from his comment on post 15 of this thread...
https://sprinter-source.com/forum/sh...t=65480&page=2
His last comment then was that he was going to email Linear Logic but never posted a follow up.
Keith.
36,000 miles from New
Old 01-06-2019, 11:39 AM   #4
damien89
Originally Posted by Cheyenne View Post
Correct Dick,
Keith.
Hi everyone, i did email linear logic and there response was to try another scangauge, which i did and the result was the same (stays connecting), at that point they suggested that i take it to someone that has more sophisticated obd reading hardware and see if we manage to make a connection with obd system. Now when i was buying the sprinter the dealership hooked the xentry computer and worked perfectly. So im beginning to believe that mercedes has devised a way to keep us out of the system.
Old 01-06-2019, 01:19 PM   #5
Winterbagoal
Does it connect to a different vehicle's OBDII? Can you try another (gas powered) vehicle to see if it's the SGII, or the Sprinter's OBDII ?
Also, mine works with my Sprinter cab chassis, but I sent it to Linear Logic to get the firmware/software upgraded/flashed to 4.22+ level so it would work with the custom X-Gauges created by G. Chappell and James DeLong (of LL).
Mike.
2018 (2017 Sprinter Cab Chassis) N24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Winterbagoal is online now   Reply With Quote
The Following 2 Users Say Thank You to Winterbagoal For This Useful Post:
gchapell (01-07-2019), Vailcomp (02-26-2019)
Old 01-06-2019, 03:41 PM   #6
Damien: did you *try* forcing the communications protocol?
(if you have a 2nd pre-2016 NCV3 available, you can snoop the ScanGauge to see what protocol IT chose)
Old 01-06-2019, 05:10 PM   #7
damien89
Yes it does, the other scangauge that i tried works all day long on my transit.
Old 01-06-2019, 05:11 PM   #8
damien89
How do i force the communications protocol?
Old 01-06-2019, 05:12 PM   #9
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
But will this ScanGauge work on your Transit or the one off your Transit work on your Sprinter?
Old 01-06-2019, 05:14 PM   #10
Winterbagoal
So, you have 2 X Scangauges? You say "the other scangauge" works on another vehicle. Your Transit.
I meant you should try the same SGII that won't connect to your Sprinter, on a different vehicle, preferably gas, but not critical.
Unless I'm misreading your comments.
Dammit Cheyenne, you asked my question.
Mike.
