Old 05-05-2018, 05:23 PM   #51
Ned D
Default Re: Dr. A Tech Alert- Ball Joints
The tires are brand new, the dealer I bought it from said the previous tires were completely shot. Good chance the alignment needs a look since the previous tires were so shredded, but won't be able to see for a bit on the new tires. The tires they put on were just cheap-o no name brand, so if they get a bit beat up before I notice the wear, oh well. I'd like to get some better ones eventually, but also no point in doing that now with brand new tires having just been installed.
I'm converting it to a camper, so I'll be slowly adding weight as I move along. Headed on a big road trip in 7-8 weeks so maybe I'll do that before then.
Thanks for the advice.
Ned D is offline   Reply With Quote
Old 06-18-2018, 04:33 PM   #52
gilee
2005 Sprinter Van 2500
Hi everything,
and thank god I read this post before I start jumping into fixing/replacing my ball joints.
And thank you Dr. A for this.
I have a 2005 Sprinter, and trying to convert my registration to RV, and DMV Inspection failed me today, ... mostly little things, but one of them is wheel too much play. told me most likely ball joint or tie rod.
I will need to jack up the Van to check myself.
From reading this entire post, and links, the PDF files I downloaded it.
I want to confirm before I go out to check the wheel's play myself.
I see most people talk about "3mm of LATERAL play NOT axial play"
Sorry if I don't quite understand Lateral and Axial....
Once I checked up the Van, with front wheel hanging in air.
What should I check?
1) Lateral means - pull and push the Wheel in and out for play?
2) Axial Play means - wheel has up and down play? (which this is NOT matter?)
Thank you guys!!
I hope this applies to me and I can avoid an expensive repair.
gilee is offline   Reply With Quote
Old 06-20-2018, 04:56 PM   #53
silosignal
Lateral Play
https://goo.gl/images/E5rYRx
silosignal is offline   Reply With Quote
Old 06-20-2018, 08:30 PM   #54
That Google image:
So the "lateral" apparently means *vehicle* side-to-side, not just *wheel* side-to-side.
Bobnoxious (06-20-2018)
Old 12-13-2019, 03:42 AM   #55
JeremyW
Thank you for posting this alert. I took my 2006 3500 to a reputable universal alignment shop on Phoenix, AZ and was told I needed $850 in new balljoints and labor before they could do the alignment. Coincidentally there was another 2006 sprinter in that morning for an alignment appointment after me and the vehicle owner and I had a nice chat in the waiting room. I decided to take the vehicle home and visit the forum and read up before agreeing to the work and came across this thread and the supporting documentation. I called the shop back and spoke to the tech who examined my vehicle and sure enough he used traditional evaluation methods and then made his misdiagnosis and expensive recommendation. As polite as I was, he didn't appreciate me challenging his expertise. I asked him if he happened to work on the other 2006 sprinter that was right after me and he said yes. I asked how that inspection went and he said "the balljoints were bad on that one too." Since the vehicle is new to me and I was interested in knowing if there were any maintenance items I haven't spotted, I took it into Mercedes Benz for service today and they did the alignment and confirmed my ball joints in perfect working order. Unfortunately, I didn't get the contact info for the other sprinter owner (who mentioned being a forum user) and hope he too did some homework before agreeing to the work.
I appreciate this forums extensive resources and community. It is empowering to have such a vast knowledge base!
Jeremy
2007 LTV Serenity built on 2006 T1N 3500 Chassis
JeremyW is offline   Reply With Quote
Old 12-14-2019, 07:00 PM   #56
lindenengineering
Jeremy
Jeremy--Fellow forum friend and after reading your post "Defender of the lower control arm ball joint!"
Let me first state that the T1N Sprinter and its suspension ball joint perceived excess wear is not NEW !
In fact "If" you are old enough , worked in Europe in the auto repair trade, you would aware of the Vauxhall / Bedford CF ball joint debacle! Fraught with MOT failures, customer "howls of foul" similar to the Sprinter no less !
It too was was available mostly in white, had a similar uses, & van following aficionados and rusted like a rotten old pear hence its nickname in the trade:-
The "Luton Oxidizer" .plus its Italian equivalent the "Torino Oxidizer'!
Yertiz ! Gone but not forgotten
https://www.google.com/search?q=bedf...hrome&ie=UTF-8
If you jacked the bloody thing up after a few thousand miles in service it had what was interpreted as "ball joint play" much like the Sprinter aka Stuttgart Oxidizer . With so many annual MOT failures, & people getting "RED UN's" the Ministry issued a directive as the discarded "A" serviceable control arms piled up in repair shops' scrap bins .
In short, that directive was to put the van on a set of alignment turntables and plot the steering movement. Any substantial wear would instantly show up to the trained operative when subjected to this test . (trained operative! key words here!
Its part of why if some wear is observed on today's UK MOT test but not deemed excessive, is noted on record against your vehicle for the next annual MOT inspection. As "Observation"!
Now in the case of the Sprinter, although the construction of the ball joint has moved on since the 1970's with internal plastic encapsulation, however the same basic test applies!
Confirmed by their factory approved alignment rig with Rombus softwear .
Now if you are trained on that platform as an operative you should know that!
Going to an independent alignment shop has its cost benefits, and equally it has potential problems as you have have discovered being a consumer.
The business of alignment and steering inspections has been largely been driven down by de-skilling & paying operatives around $15 to $18 /hour.
The business frankly is price sensitive and has to be competitive,.
Here in the USA the buying public do not believe in having trained skilled specialty personnel in under-body chassis auto repairs, and demand low prices for these alignment service which for the most part are loss leaders in the march to up-sell replacement parts & repairs.
(get the ideas???)
Furthermore an Independent shop might not have the latest machinery with software updates nor service info for a Sprinter (Rombus etc) being expensive at about $70,000!
A dealer on the other hand is forced to have such alignment rigs in the shop and employ a higher level of service personnel, but the tariff will be higher as rule due to overheads.
I hope that gives you a more amplified vision of the prevailing auto repair business here in the USA.
Old 03-03-2020, 10:50 PM   #57
Jay Hughart
Took my van to the closest shop to get an inspection sticker as mine was months dead. Now this shop not to mention any names but the ONLY shop on Route 21 within the city Limits of Charleston WV Failed my ball joints. Tech showed me the up and down play of about 1/4". I was polite and told them I would Order some and bring it back. Came home wed searched for procedure, printed out the PDF and took it back to them within like 10 mins. The tech looks at me like Im stupid and then the shop owner (Mike) comes out and I tried to show him the paper and he states "We are not putting a sticker on unless it has new ball joints" I even read the procedure to them (Cuz honestly I dont think they can read) So then I say ok so I take it somewhere else or I can call the State police and let them know that you dont know what you are doing. Boy did I get a "GET THE F YOU C K off of my lot!" You have to really not care about your shop to treat an Automotive Mechanical inspector that lives within walking distance of your shop like that. I knew for certain this van would pass before I took it there. Hey MIKE how much biz did this one post cost you over a $15 sticker that I got 5 mins later? And MANY thanks to DOC A. for talking with me on a couple of problems. Anyone traveling or in Charleston WV hit me up if you need anything. I am an (expired) ASE MASTER with ADV engine performance. I have worked in multiple dealerships and have been Inspecting Vehicles for 20 years.
Jay Hughart is offline   Reply With Quote
