Old 11-14-2016, 05:38 PM   #11
lindenengineering
Default Re: Urgent crankshaft bolt info
Don't forget the stepped cone abutment washer that goes on the balancer pulley arr!
The steeped undercut provides a vital clamp load on the pulley and it becomes work hard over time.
You can't take short cuts and risks with this attachment.
Dennis
lindenengineering is offline   Reply With Quote
Old 11-14-2016, 05:43 PM   #12
chiro1973
Yep, definitely getting the washer as well. I wonder if I should get a crank case seal just in case. I've been told there usually isn't an issue damaging it when removing the pulley though.
chiro1973 is offline   Reply With Quote
Old 11-14-2016, 06:06 PM   #13
Replace the seal for sure. It's a $15 part and there's no reason to risk a crank leak for 15 bucks. You will need to make a tool to push the seal in. You can use the old crank bolt and a couple of very large washers with a piece of wood as a spacer to make a cheap and quick DIY tool.
