I just sent the following message to Europarts-SD. I think it captures what's been going on. I've still never heard any roaring of the fan when engine is hot. And on more demanding drives, the van has overheated. Most cooling components had already been replaced recently, except the viscous fan clutch. Whether related to previous overheating or not, the reservoir on my radiator had split, the water pump had begun leaking, and even the aux pump started leaking at the seam. Normal operating temp is about 190F, climbing up to 220F or even nearer 250F on hotter days. My desire would be to go out on the road without worry of overheating on longer climbs. Van has 190k on it currently.
Also, to be appropriate for this thread, I will add that I was able to change the fan clutch by only removing the heat shield. I was able to feel around for the 8mm allen bolt and eventually got the allen wrench into it. The handle of my allen wrench is pretty long (8" ?) and provided enough torque. I used a screwdriver to hold the fan from turning. Once the bolt was loose, I switched to a shorter allen wrench. My hands are medium size and that probably helps. Also, I wore latex gloves which I think saved my knuckles from scraping on the fins of the radiator. Older fan clutch was Mercedes, new one is Cool Xpert (?) from Europarts.
First of all, thank you for your great selection, helpful product descriptions and quick shipping! I’m a happy repeat customer.
I received the viscous fan clutch I ordered recently and installed it. But I seem to still have some issue.
My hope was that the new clutch would improve the cooling on my 2005 Sprinter 2500. On a local hill, the van regularly borders on overheating, especially on a hot day with a/c running. Its a relatively short drive - 20 minutes uphill, and then 20 down the other side. I’m not towing anything but I do have some amount of load in the van. Recently with the old fan clutch, I pulled over while van was quite hot (~220F according to the dash meter) and while it was still running, I verified that the fan could be easily stopped with a piece of soft foam. This, I believe, indicated that a new clutch was needed.
With the new fan clutch installed, I made the same drive, Again the van came close to overheating, and I pulled over to test the fan clutch. Even with the new clutch, I was able to easily stop the fan from turning while the engine was hot (again ~220F) and engine running.
Perhaps I received a bad unit ? Should I send this back for a different fan clutch ? What do you recommend at this point ?
So that was my message to Europarts. But I'd like to pose these questions here as well. From all I've read on this forum, even a new viscous fan clutch part might not behave as desired.
