Go Back   Sprinter-Forum > Miscellaneous > Test Area
Test Area Place to develop your Forum skills.
Old 12-04-2016, 05:46 PM   #1
Lighthawk
Default testing, testing . . . do not adjust your monitor
copy & paste image address:
https://photos.smugmug.com/Other/Exp...4.40.51-X3.jpg
copy & paste image, then insert using photo icon:
Lighthawk is offline   Reply With Quote
Old 12-04-2016, 05:51 PM   #2
Default Re: testing, testing . . . do not adjust your monitor
Let's see if it works for me using the postcard:
Lighthawk (12-04-2016)
Old 12-04-2016, 05:55 PM   #3
You did not appear to use the postcard icon.
*Both* your first and second links had the "url" markup.
[url] https://photos.smugmug.com/Other/Exploration-vehicles/Sprinter-4wd/i-wPnZV6W/0/X3/2016-11-19%2014.40.51-X3.jpg [/url]
The fact that the "url" is lowercase looks like you manually typed it. (the icons insert uppercase)
But the real problem/fix is that the postcard uses "IMG", not "URL"
[IMG] https://photos.smugmug.com/Other/Exploration-vehicles/Sprinter-4wd/i-wPnZV6W/0/X3/2016-11-19%2014.40.51-X3.jpg [/IMG]
IMG links to an externally-posted image ... so if the target is NOT a .jpg, .gif or similar, it won't show it.
p.s. i added spaces in the above example for clarity. The UUPERCASEing is not required, "img" works too.
Old 12-04-2016, 06:50 PM   #4
Lighthawk
Okay, trying this again . . .
Click on postcard icon above, then paste image address, which is a jpg
Old 12-04-2016, 06:53 PM   #5
Lighthawk
Ta da!
Thanks for helping prod me along.
Here's a dropbox jpg, pasted into the postcard icon
Old 12-04-2016, 06:54 PM   #6
Lighthawk
DB did not work.
Let's try manually adding the IMG tags
Old 12-04-2016, 06:56 PM   #7
Lighthawk
Nope.
Let's try copying the image address (right clicky) with postcard
Old 12-04-2016, 06:58 PM   #8
Lighthawk
Voila! Posting a jpg from dropbox can be done, same way as Smugmug.
DO NOT USE THE SHARING FUNCTION FROM EITHER SITE.
Instead right click and copy the image, then use the postcard and paste the image address.
Other forums do it more simply IMHO and also allow BBC code which let's you control the size of the shared image.
But, at least I've learned how to post images.
Old 12-04-2016, 07:00 PM   #9
Lighthawk
Now, for extra credit, let's see if it's possible to share a pdf file from DB
[IMG]view-source:https://www.dropbox.com/home/shared/Vehicles?preview=Build+Your+Mercedes+Van+_+Mercede s-Benz+Vans.pdf[/IMG]
Old 12-04-2016, 07:01 PM   #10
Lighthawk
That didn't work.
Here's a link created by DB
https://www.dropbox.com/s/y7t9no0rhz...0Vans.pdf?dl=0
Now pasted into the postcard
