Old 01-11-2019, 05:11 AM   #1
Denny crain
Default Rear a/c
Iíve been reading on this forum for over a year. I finally am close to buying my sprinter . Its going to be a daily driver, but also a weekend camper. I have 2 kids, and want the passenger van with windows. I really want rear AC as I live in Colorado but will travel to Florida during the summers. I feel like rear air is a must but am afraid I will not be able to stand up in van after the conversion. Does anyone have a conversion with rear air? Would you order it if you were ordering a new van?
Denny crain is offline   Reply With Quote
Old 01-11-2019, 05:00 PM   #2
Ianmoore
Default Re: Rear a/c
Denny,
I am on my second Sprinter. I had my first since 2007. Both are passenger vans, 170, high roof. I am converting my older model and am removing the rear AC. I just couldn't come up with a way to keep it, and still have room for solar, as well as needed ventilation. It is a bit of a feat to get it out, but i think it is better for the needs in a conversion
Best
Ian
Ianmoore is offline   Reply With Quote
Old 01-11-2019, 05:46 PM   #3
markxengineering
From my memory of taking mine out, the important components that took up head-room were in the very back of my T1N. The more forward portions were all ducting that could either be eliminated or re-made along the sides of the van, leaving a channel down the middle with headroom. I chose to delete AC to make space both inside and out, but I would not if I planned to be in Florida during summer.
2006 Hi Top Window Van 140"
markxengineering is offline   Reply With Quote
Old 01-11-2019, 05:48 PM   #4
TamagoVan
2016 144 High Roof
TamagoVan's Avatar
My partner is 6' 1" and he couldn't stand upright with the interior rear AC ducting in our high roof 2016, and that was before we added insulation to the floor. For us it had to come out, even before the considerations for the rooftop real estate we wanted for vents and solar.
There are aftermarket AC units you can add that take up a lot less space on the roof and can be ducted differently.
TamagoVan is offline   Reply With Quote
Old 01-11-2019, 05:54 PM   #5
HarryN
IMHO, It is unrealistic to be in FL in the summer without air conditioning.
More or less you get into a decision making mode:
- How much insulation do I REALLY need in the floor (making it thicker vs more or less leaving it at the factory thickness)
- Can I change the layout to accommodate
In most van brands, I hit my head going into the center of the back door. (5-11) Just barely scrape under the sprinter.
One possible option is to build up your conversion so that one side is mostly aisle, and the other side is build out. That way you aren't constantly going down the middle of it.
Power systems for conversion vans and emergency preparedness.
https://wirlnet-inc.square.site
The Following User Says Thank You to HarryN For This Useful Post:
ptheland (01-11-2019)
Old 01-12-2019, 04:44 AM   #6
ecowhale
Innovative CamperVan
ecowhale's Avatar
I have a rear mounted air conditioner build disclosure you may consider: http://www.EcoNeato.org/ac.html
ecowhale is offline   Reply With Quote
The Following 2 Users Say Thank You to ecowhale For This Useful Post:
InterBlog (01-12-2019), Surveillance Van (01-12-2019)
Old 01-12-2019, 01:38 PM   #7
InterBlog
Originally Posted by Ianmoore View Post
... I just couldn't come up with a way to keep [the rear a/c], and still have room for solar, as well as needed ventilation. ...
Several of us have vaulted our panels over the top of our rear a/c units. My husband and I added 300 watts, although we have room to add two more panels if we ever need them.
A few folks have covered their entire roofs with vaulted solar panels. Not only does it give room for everything underneath, but it serves as a de facto "tropical roof" of the style that is often done in places like Africa and the Australian outback, where they install a false roof with an air gap underneath to cut down on heat gain.
The 11,000 BTU Dometic a/c is tucked under the panels, and the Fantastic vent is directly in front of the array:
Somebody else's rig, slightly larger vaulted array, with vent fan further forward than in our model:
InterBlog is offline   Reply With Quote
Old 01-12-2019, 02:01 PM   #8
InterBlog
General comments -
(1) I am not able to visualize the build that you are considering. "Passenger van with windows...daily driver... weekend camper". You might get more targeted responses if you provide more design details on how those features would all work together. How many windows? Where? Seats distributed among camper van infrastructure where and how?
(2) DO NOT UNDERESTIMATE the heat burden that you are going to have in Florida. I predict that standing up (height clearance) will be the least of your worries. You may have to stoop a little bit as you pass under your roof a/c unit, yes. The alternative would be baking to death. On an average summer day in Houston, the interior of my Sprinter can easily reach 107 degrees even when I have all of my window reflectors in place, and my vent fan running. This is not a matter of comfort - it's a question of personal safety.
I live in southeast coastal Texas, which is comparable to Florida (actually worse, and plus you would have to drive through Texas and every other Gulf Coast state to get back and forth). There is NO WAY I would purchase a spec van build if your description = my target usage - I would either have it built, or I'd build it myself, paying extra attention to the issue of insulation:
(a) Search for Hein's products and the numerous threads herein on maximizing van insulation.
(b) Summer heat management in Sprinter vans has been discussed ad nauseam before, both here and on other forums. About two years ago I hatched this "declaring war on summer heat gain" thread on another forum (Airstream builds, but the thread was almost exclusively confined to Sprinters). You might want to glance over those 260+ replies to see if there are any ideas in there that would be of use to you in your application.
Meme'd van pic - someone had gotten understandably desperate and had wrapped their van 100% in solar reflecting sheets, and I thought it needed an embellishment:
Old 01-13-2019, 05:09 AM   #9
Denny crain
I want a passenger van which comes with windows all around. I will keep the first row of factory seats to keep everything legal and crash tested seats for my kids to ride in. I am building it myself (I am a carpenter and also build muscle cars) with a kitchen, bath, and beds, finished to be able to operate as a full time home. It will be very well insulated. I will not be in Florida much as most of my time will be camping in the Rockies but will travel to the Panahandle in the summers for a few weeks a year.
I have read about summer heat in Sprinters a lot. I am more worried with rear passengers while driving, not while camping. Most of the articles I read talk about heat while living in the van. I feel like rear air would make for a more comfortable ride while going down the road. I am wanting to use reclaimed lumber on ceiling and am a little worried with looks and head clearance when walking around with the factory rear air.
I found a van I with all the options I want and it has the factory air that I am looking at next week. Before I pull the trigger I just wanted a litttle feedback. Thanks for all the help
Old 01-17-2019, 03:46 PM   #10
linnmagic
Hi, I also have 2016 high roof with rear AC, How hard or easy to take it out? Thanks.
linnmagic is offline   Reply With Quote
