Old 06-21-2018, 12:56 AM   #21
CJPJ
2008 3500 170"ext. 3.0 V6
CJPJ's Avatar
Location: Contra Costa California, Douglas County, Oregon
Default Re: Coolant replacement
Originally Posted by Bobnoxious View Post
What color is Zerex G-05?
Yellow? https://www.valvoline.com/our-produc...engine-coolant
CJPJ is online now   Reply With Quote
The Following User Says Thank You to CJPJ For This Useful Post:
Bobnoxious (08-03-2018)
Old 10-05-2018, 05:10 PM   #22
TROLL
2007 Winnebago View 23H
I bought my 06 Sprinter I-5 with blue Mercedes coolant in the engine (engine was rebuilt in 2016). I have a coolant leak that I need to address, and I also need to top off the system before driving again. Is it ok to buy Zerex G-05 locally and mix it with the Mercedes blue coolant? I've read answers that lean toward yes but trying to get a little more definitive before buying. Does anyone know if its definitely ok to mix these two? Thanks!
TROLL is offline   Reply With Quote
Old 10-05-2018, 05:18 PM   #23
Yes, all hoat coolants can be mixed.
TROLL (10-05-2018)
Old 01-06-2019, 08:45 PM   #24
alexk243
KulAdventure
alexk243's Avatar
Mine appears to be gold colored
2004 T1N Passenger 140" (Conversion in Progress - Build Thread)
My Website/Blog with Projects and Write Ups on my Van
alexk243 is offline   Reply With Quote
Old 01-07-2019, 02:53 PM   #25
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
A reply to an older post.
Originally Posted by silosignal View Post
G48 is very similar to G-05.
My understanding is that the G48 formulation was required to meet Euro standards. I believe it relates to their regs... phosphate free. (Maybe gleaned from previous BeVo information?)
There is no reason to stray from the G05 HOAT formulation if you are in N. America.
It appears that Zerex G05 has fallen off the list for MB325.0 coolant. Not because it isn't approved at all, but because it is no longer approved for Euro markets. It has been listed in Owner/Operator Manuals so it remains approved. MB states that the Operator Manual always applies (evergreen).
Added:
"The G-30 is basically the same as DexCool.
The G-05 has more reserve alkalinity than the G-48 and has replaced G-48 as factory fill for Mercedes. [I believe G48 has replaced G05. - vic] They both originate with BASF in Germany in the Glysantin line:
http://www.basf.de/en/produkte/chemi...0qgQ5i2wbsf1i6
The G-48 is nitrite-free, which means unlike G-05 it can�t be used with wet sleeves. G-05 has a smidgeon more silicate than G-48.
And its [G48] availability in North America is thin, indeed. Valvoline suggests using G-05 to replace it."
https://www.bobistheoilguy.com/forum...&Number=613531
Zerex G05 has properties which G48 does not.
Nitrites = protect against cavitation.
More reserve alkalinity = longer coolant service life.
Also. (Not G05 specific.)
Carboxylates = cavitation protection.
https://www.machinerylubrication.com...t-fundamentals
Use G-05 in your T1N. Your head gasket will thank you. Replace every 5 years or 100k. Which ever comes first. Nothing lasts forever.
Also, running your van diluted by DI/distilled water isn't the best idea. Running it for 3 seconds won't do anything. Run it for 5 minutes and you may find that your water pump has started to weep a bit and then full on leak. Water is a decent lubricant but coolant DOES add proper lubrication for the water pump. I used to do the distilled water flush ~10 years ago in Saabs cuz I thought it was brilliant. It's not.
My mode is to change the coolant on the proper schedule. Coolant changed on proper schedule is perfectly serviceable product. It is toxic waste to the EPA, but not to your engine. I won't use any flush chemicals or procedures unless visual inspection or symptoms show the need.
Old 04-09-2019, 02:07 AM   #26
seabiscuit
I drained radiator through the metal coolant pipe connection, two gallons. I filled up with two gallons. Is this correct?
North America - Maryland - early 2002 Freightliner 2500 Cargo Van; Engine - OM 612, 2.7 litre Diesel, 5 cylinder; 140" length, high roof; rear axle ratio - 3.73; white, windows in side and rear doors, 15 inch tires.
seabiscuit is offline   Reply With Quote
Old 04-09-2019, 02:12 AM   #27
lindenengineering
Not quite!!
Did you drain the block?
Dennis
Old 04-09-2019, 02:35 AM   #28
seabiscuit
No.
Old 04-09-2019, 03:16 AM   #29
lindenengineering
Then you didn't flush it properly.
The method is to remove the hose from cooler to block stub and back purge it with a garden style hose under pressure, obviously with the lower hose removed from the radiator stub to allow waste coolant expulsion & collection.
Dennis
