Old 01-20-2020, 08:14 PM   #1
VanLifeFreedom
Default High Beam Signal wire?
Anyone on here know what color wire is the 12V+ signal for the highbeam on the VS30?
I was test lighting the wire feeding the plug on the headlights and when I tap the green wires it turns off the high beam for some reason?
Any help would be appreciated.
Tom
2007 NCV3 371K miles // Darth Vander // Freedom Vans
VanLifeFreedom is offline   Reply With Quote
Old 01-21-2020, 11:27 AM   #2
JFC
Default Re: High Beam Signal wire?
There is none if you have Led...
2006 158 sold
2015 170 4x4 sold
2017 144 4x4 sold
2019 144 4x4 wow !
JFC is offline   Reply With Quote
Old 01-22-2020, 11:36 PM   #3
VanLifeFreedom
Thank you for the confirmation there. It is the LED headlights
Thanks agin cheers
Old 01-27-2020, 05:31 AM   #4
Rauch
I was just testing the same today. There is some Can Bus voltage 2V give or take and one 12V wire, but nothing changes with highbeam activation. Any ideas on tapping highbeam to run driving lights off a relay on the vs30 with LED? Maybe allow the negative on the fog lights to trigger the relay?
Rauch is offline   Reply With Quote
Old 03-02-2020, 03:06 AM   #5
Laserbill
Any idea on what to use for those with halogens? Would like to trigger aux lighting via high beams as halogens leave something to be desired off road.
Laserbill is offline   Reply With Quote
Old 03-10-2020, 09:57 PM   #6
Wreckingcrewsdad
Interested in doing the same
Wreckingcrewsdad is offline   Reply With Quote
Old 03-12-2020, 06:12 PM   #7
Overvand
Overvand's Avatar
Sounds like a great use for the PSM (Parametric Special Module) option code ED5.
Overvand is offline   Reply With Quote
