Old 02-04-2020, 07:47 PM   #11
JFC
Default Re: Front speaker upgrade
Originally Posted by Egb View Post
@jfc did you pull up on the center speaker metal grille itself ?
Or did you first remove the storage box / CarPlay connection / phone charger unit, and then get at the speaker ?
I just pryed to speaker cover.
Easy
2006 158 sold
2015 170 4x4 sold
2017 144 4x4 sold
2019 144 4x4 wow !
JFC is offline   Reply With Quote
The Following User Says Thank You to JFC For This Useful Post:
Egb (02-04-2020)
Old 02-06-2020, 11:02 PM   #12
Egb
Adding pics of center speaker grille for others to see
Thin trim tool will get it out
File Type: jpeg A6D6A50B-957B-4BFA-B366-BD193D089B5D.jpeg (121.1 KB, 145 views)
File Type: jpg A73F3ED1-6E25-4064-A333-9EA81CBC41A0.jpg (65.8 KB, 136 views)
Egb is online now   Reply With Quote
The Following 7 Users Say Thank You to Egb For This Useful Post:
Gski (03-26-2020), jimdog (02-20-2020), lndscpe (02-09-2020), Mr Makai (02-19-2020), NoSoupForU (02-20-2020), webdbbt (02-11-2020), wquek (02-07-2020)
Old 02-06-2020, 11:15 PM   #13
Egb
@jfc you disconnected Grey and purple wire connector - what does the second connector to the center speaker do ? (Grey and green wires)
Old 02-07-2020, 12:10 AM   #14
johnshmit
johnshmit's Avatar
That speaker is dual coil. Both channels are connected to it, left and right
johnshmit is offline   Reply With Quote
The Following 2 Users Say Thank You to johnshmit For This Useful Post:
Egb (02-07-2020), JFC (02-11-2020)
Old 02-12-2020, 02:55 PM   #15
Egb
@johnshmit i was able to confirm that if you disconnect the white connector to the speaker then you lose the "SOS" functionality... your MBUX screen will show "SOS Not Ready" in top right corner, and the button in overhead console will remain lit when you drive... so can't disconnect that one... only the black one can.
The Following User Says Thank You to Egb For This Useful Post:
webdbbt (02-15-2020)
Old 02-15-2020, 03:29 PM   #16
Agnes16
Wow. It took all over 30secs to disconnect - did it before I even left the Dealer lot the other day after signing papers on our '19 170 4x4 crew. Very noticeable change from the initial test drive. Thanks All!
Agnes16 is online now   Reply With Quote
Old 02-19-2020, 08:02 PM   #17
Mr Makai
Did the disconnect today. Easy and a major improvement.
Sent from my Moto Z (2) using Tapatalk
Mr Makai is offline   Reply With Quote
Old 02-19-2020, 08:25 PM   #18
Mr Makai
Originally Posted by JFC View Post
Today project;
How do you remove the door panel on a VS30?
Old 02-20-2020, 01:13 AM   #19
Egb
Hi Mr Makai
+ Three exposed screws along bottom edge
+ 5 circular plugs you need to pop out (trim tool) with screws behind them
_ 2 in lower cubby, 1 behind door handle, 1 in door pull pocket, 1 at top outermost (facing your elbow when seated)
+ Pop out small trim piece around door lock stalk where it meets glass
You can then start at the bottom and work your way around popping the plastic clips
The bottom edge of the door panel has hooks that hold it to sheetmetal
Once you’ve popped off all the body clips, the door panel will rotate out so you can unclip the wiring and the door rod from the door handle
Then the door panel can rotate down towards you a bit more and you can lift it out of the recess that the hooks sit in
There’s a couple YouTube videos if you need visuals
If I find url I’ll post it up
Old 02-20-2020, 01:22 AM   #20
Egb
NCV3 url - pretty close - you can probably figure out the rest
https://sprintervanusa.com/2016/09/1...dash-speakers/
wquek (02-20-2020)
