Old 11-12-2019, 03:56 AM   #11
slamit
www.cacampervan.com
Default Re: Trouble removing headliner
This should help...its pretty simple, the hooks hold the airbag in, you need to unhook them and it drops. The A pillar has a screw...so pay attention to that as well.
The Following 2 Users Say Thank You to slamit For This Useful Post:
stevesvans (11-12-2019), Wreckingcrewsdad (11-15-2019)
Old 11-18-2019, 04:22 AM   #12
mcjohnson5174
I have a 2019 and have removed the headliner....based on your picture the trim piece behind the windsheild (starting from dash and doing up) needs to be removed first. There is an airbag logo, that comes out and there is a screw behind it...can be somewhat had to see too. There is also a speaker like cover on the dash that needs to come up - just pops up.
Once this piece is removed, the headliner will come out.
I didn't worry about the airbag clips when removing, only when reinstalling. a couple of the christmas tree like clips broke at the back, others went well.
Hope this helps.
Matt
mcjohnson5174 is offline   Reply With Quote
The Following User Says Thank You to mcjohnson5174 For This Useful Post:
stevesvans (11-18-2019)
Old 01-25-2020, 01:39 PM   #13
nickbokhoven
A close up of the clip. We took ours out yesterday with the help of this thread and installed raammat and Thinsulate before replacing. Less than a two hour job.
nickbokhoven is offline   Reply With Quote
The Following 2 Users Say Thank You to nickbokhoven For This Useful Post:
stevesvans (01-25-2020), Wreckingcrewsdad (02-01-2020)
Old 03-26-2020, 04:33 AM   #14
Dendisch
I have a 2019 HR cargo van and can't even get to the headliner before removing these huge styrofoam blocks behind it. I have not yet figured out how to remove them without breaking them. Any pointers? Thanks
Denis
Dendisch is offline   Reply With Quote
Old 03-26-2020, 06:58 AM   #15
wquek
Denis
The styrofoam boards on the B pillar of my crew van are attached using double sided tape. I just used a knife to cut through it. I think on the cargo vans there is a bigger piece. Maybe it is taped on as well.
wquek is offline   Reply With Quote
The Following User Says Thank You to wquek For This Useful Post:
Dendisch (03-31-2020)
Old 03-26-2020, 04:33 PM   #16
Egb
Pics of the foam blocks
I think everyone who has removed theirs broke some part of it off
Definitely has to push up and out to remove - not easy without breaking a portion of it
The NEW price from the dealer is INSANE on these btw
Look at my pics and youíll see where mine broke and I glued the pieces back in
Maybe thatíll give you an idea how to become one of the few to remove them without breaking off a piece
Good luck
Egb is offline   Reply With Quote
The Following 2 Users Say Thank You to Egb For This Useful Post:
Dendisch (03-31-2020), Overvand (03-27-2020)
Old 03-31-2020, 04:52 AM   #17
Dendisch
Thanks, these pics are definitely helpful. Not sure I can manage without breaking the foam, seems like it's designed to break ;-(
I have a few more things to do before I will get to this step, so I can ponder the options.
Thanks again.
Denis
Old 03-31-2020, 08:18 PM   #18
Egb
Denis
Pull IN towards the center of the van along the top horizontal edge
while pushing UP with the other hand along the bottom horizontal edge
Good luck
