Old 11-16-2016, 08:06 PM   #11
zwsandman
Default Re: CAUTION FOR ALLOY WHEELS and Steel Spare
I recently bought an 06 2500 140in WB . My spare is definitely steel... I'm not sure what wheels i have, a magnet does stick to them (no super strongly), they are silver in color. Wondering if these are "alloy" wheels? i don't have any separate bolts with my jack. Just found out i gotta take a 1000 mile round trip ride to go to funeral and i came across this thread, wondering if I can use my spare if need be!!
zwsandman is offline   Reply With Quote
Old 11-16-2016, 10:01 PM   #12
LooseRocks
A picture would be helpful.
LooseRocks is offline   Reply With Quote
The Following User Says Thank You to LooseRocks For This Useful Post:
73shark (02-13-2018)
Old 11-16-2016, 10:49 PM   #13
CJPJ
2008 3500 170"ext. 3.0 V6
CJPJ's Avatar
Location: Contra Costa California, Douglas County, Oregon
Originally Posted by zwsandman View Post
I recently bought an 06 2500 140in WB . ... a magnet does stick to them (no super strongly), .. wondering if I can use my spare if need be!
If a magnet sticks; then they have iron in them. They are a iron alloy = Steel wheel.
The stock spare is also Steel.
CJPJ is online now   Reply With Quote
Old 12-19-2016, 03:43 PM   #14
zwsandman
Here is a pic of my wheels, with the info posted above they are steel correct ? so no issues using my steel spare?
Old 12-20-2016, 02:04 AM   #15
Boxster1971
2012 Sprinter 3500 Ext
Boxster1971's Avatar
Yes that is a steel wheel - same as your spare.
-- Mike
2012 Sprinter 3500 EXT Airstream Interstate
Boxster1971 is online now   Reply With Quote
Old 05-28-2017, 05:10 AM   #16
Van Campa
Van Campa's Avatar
Originally Posted by Dave D View Post
My 2016 came with factory alloys and a matching alloy spare, and I thought this was standard practice for Mercedes. Is this warning primarily folks with aftermarket wheels or upfitted RVs where they cut corners with a steel spare, or did some older sprinters not come with all the same wheels from the factory?
My 2002 313CDI had factory alloys and steel spare. The extra bolts were in the passenger side compartment with jack.
I had to use that spare once and luckily had those spare bolts.
Sent from my SM-N910U using Tapatalk
Van Campa is offline   Reply With Quote
Old 07-14-2017, 05:30 PM   #17
Kirk
Anyone know where I can order a set of lugs that will work with the steel wheels? I only need 6 of them for my spare as I installed new aftermarket wheels and kept the steel spare and sold off the stock wheels with the lugs included. I now need to get 6 lugs that work with the steel wheel to keep in the van.
Kirk is offline   Reply With Quote
Old 07-14-2017, 05:37 PM   #18
Lloyd Crochet
Lloyd Crochet's Avatar
Any auto parts store
Lloyd Crochet is offline   Reply With Quote
Old 07-15-2017, 04:28 AM   #19
Boxster1971
Doubt that any auto part stores will have lug bolts for Sprinters - but I could be wrong.
Lots of sources on-line. Here is just one.
https://www.eeuroparts.com/Parts/652...ug-Bolt-18913/
Also a dealer would be a good source.
-- Mike
The Following 2 Users Say Thank You to Boxster1971 For This Useful Post:
Aqua Puttana (07-15-2017), Kirk (07-20-2017)
Old 02-12-2018, 12:54 PM   #20
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
Michelin Truck Tire Manual
Not really related to lug bolt length. TooMuchHair referenced a very nice tire manual by Michelin.
There is a section specific to RV's.
An example of included info.
Originally Posted by TooMuchHair View Post
I copied this paragraph about mismatched dual tires from the Michelin truck tire handbook, page 142.
5. Dual Mismatch Height
Dual mismatch tread depths (tire height differences)
will cause irregular wear. Additionally, the larger tire
(the one with the greatest tread depth) will become
over-fatigued due to bearing more weight, this
accelerates premature casing failure.
Goal: Match tires in dual assembly with equal tread
depths. Well maintained fleets use +/- 4/32" of tread
depth as maximum allowable difference in overall height
between the duals.
Effect: Dual mismatch tread depths can cause a
permanent irregular wear pattern in a few weeks
resulting in early removal or a lost casing.
They also make a similar point about the importance of matching air pressure in dual wheel pairs because of the difference in diameter causes the tires to travel different distances causing scrubbing of the tread surface, sometimes severe.
Lots of good information in this manual. Including selecting correct air pressure based on weight, which is the correct method if you can. Truckers that run lots of empty miles soon realize that the pressures necessary to carry there loaded weights can cause extreme wear at times when running empty. It is a dilemma because its just impractical to let air out of 18 tires (or?#) everytime you deliver a tanker load of fuel for example. That's one of the reason you see more trucks with lift axles, It not only gets 4 tires off the road completely, but increases the weight on the axle carrying the empty truck back to a distant load point. Win/win.
As a side note, there is some good info on page 77 about using blocking under tires properly. I cringe when I have seen people (mostly mechanics, i've never been in a campground but I have seen a few pictures of bad leveling block placement too)) make the mistakes shown in the diagrams.
Here is the link to the entire manual:
https://www.michelintruck.com/assets...anual_2011.pdf
In case the link changes:
Truck_Tire_Service_Manual_2011.pdf
Added:
More RV specific
https://www.michelinb2b.com/wps/b2bc...s_Brochure.pdf
RV_Tires_Brochure.pdf
