Old 04-02-2014, 02:34 AM   #1
-eugene-
Default 2003 sprinter 3500 rotors help
hello everyone, ive got a 2003 sprinter 3500 and im trying to buy new rotors, front and back rotors are 6 lug nuts but when im trying to buy new ones everyone just sells the 5 lug nut rotors and no one has the 6 lug nut ones. Any one having the same problem? and where could i get them
-eugene- is offline   Reply With Quote
Old 04-02-2014, 02:43 AM   #2
sailquik
sailquik's Avatar
Default Re: 2003 sprinter 3500 rotors help
-Eugene_,
You can get the OEM quality rotors at your dodge or Mercedes benz dealer.
Just take your VIN # to them and you will get the same rotors and pads that came on your Sprinter when it was
built in Germany.
Send me your VIN # and a valid return email address and I may be able to give you the OEM Dodge/Freightliner/
Mercedes Benz part numbers.
Or, you can try EuroParts-SD .ccom
They have both the fronts and rears, and may be able to sort out which you need based on your VIN.
http://europarts-sd.com/mfg-subcat-i...ID=99&scID=165
Hope this helps,
-eugene- (04-03-2014)
Old 04-02-2014, 02:49 AM   #3
-eugene-
ive checked that link but its the same thing, for rear they have 6 lug nut rotors but for the front ones are only 5 lugs, doesnt look like they have the 6 hole ones
Old 04-02-2014, 04:12 AM   #4
MillionMileSprinter
Formerly Type2Teach
MillionMileSprinter's Avatar
They do. Call them and ask. The photo is of the 2500 set.
Sprinter Mechanic
Joel Sell
For HELP, SERVICE and MORE
Old 04-02-2014, 04:20 AM   #5
Fudgefactor
2004 OM647 3500 C-Cab
The photo is representative of the item, not an exact picture. I order both the front and rear rotors from them last fall for my 2004 3500 (6 lug). If you're still not convinced call them. http://europarts-sd.com/
Fudgefactor is offline   Reply With Quote
The Following User Says Thank You to Fudgefactor For This Useful Post:
Old 04-02-2014, 04:40 AM   #6
-eugene-
The 2007-2011 3500`s are all 6 lugs on the picture though. Does 15" or 16" make a difference?
Old 04-02-2014, 05:12 AM   #7
MillionMileSprinter
Formerly Type2Teach
Don't go by the photo. Call or email them. They are very knowledgeable and have been faithfully serving Sprinter owners for years. There is even a Europarts Appreciation Thread here on the forum.
15" and 16" refer to the wheel size. Both sizes came on the 3500, but I know they are interchangeable. That makes me think that the brake disks are the same, but again, just call them. They can answer all your questions. Or you can email them, too.
Sprinter Mechanic
Joel Sell
Old 04-02-2014, 07:47 PM   #8
Warehouse 33
Warehouse 33's Avatar
-eugene- You can email me your vin # I can l get the correct part # and get you some prices for the front rotors.
-Jason
Warehouse 33 is offline   Reply With Quote
Old 04-03-2014, 02:42 AM   #9
westyventures
westyventures's Avatar
What I think most missed here is that the T1N 3500 uses 5-hole front rotors - there is a huge adaptor flange that bolts over the brake disc and to the hub with five bolts, this flange then has the six wheel studs mounted in it. There is no 6-hole disc. The rear has 6 holes.
Karl Mullendore
2003 T1N 416 140" 4x4 adventure-camper project in process
2004 Sprinter Westfalia #179
westyventures is offline   Reply With Quote
The Following 4 Users Say Thank You to westyventures For This Useful Post:
-eugene- (04-03-2014), Aqua Puttana (04-03-2014), MillionMileSprinter (04-03-2014), photogravity (04-03-2014)
Old 04-03-2014, 03:28 AM   #10
photogravity
Former Sprinter Wannabe
That is an interesting piece of information. I would have never thought that.
2002 W903 Sprinter 2500 HC 140" Wagon
2004 R230 SL600R
2007 W211 E320 Bluetec
2007 W251 R320 CDI
2013 Chevrolet Volt (Gen 1)
photogravity is offline   Reply With Quote
