Go Back   Sprinter-Forum > Classifieds > For Sale (Sprinter vans Only)
For Sale (Sprinter vans Only) Post Sprinter Vans for sale here. Vans must be driveable, otherwise, they go to the parts section here.
Closed Thread
Old 11-02-2018, 03:19 PM   #1
kentonius
enough to be dangerous...
kentonius's Avatar
Default FS: 2006 Passenger 2500 158" Camper Conversion - Wisconsin near Chicago
Life changes fast for some, so here is a chance to own one of the best model Sprinters with lots of recent new parts, maintenance, and a full camper conversion!
A/C works as do all the heat systems (has rear heat exchanger for rear passengers). No smoking, extremely clean. Includes owners manual, 2 keys, and everything else mentioned below.
The only issues is that the previous owner opened one of the rear doors on a pole and put a dent up and down the door. This does not affect the door at all, and is not rusting. I was able to replace the rear windows with no issues. Minor rust under side rails, can be treated.
Lots of costly maintenance and new parts replaced in the last 6 months:
- Bilstein shocks and struts
- Driveshaft from Driveshaft Specialists
- Upper turbo hose
- Metal turbo resonator (delete) pipe
- Newer Mercedes battery
- LED headlight bulbs
- LED light bar in front bumper
- New Espar Hydronic Heater - functions as heater "booster" to help engine warm up on cold days AND can function independent of engine to warm the cabin as an auxiliary heater.
- Back-up camera with large widescreen monitor
- New AT tires
- Fuel filter
- Cabin air filter
- Intake air filter
- Windshield wipers
- Stebel Nautilus horn - much louder than stock
- Pioneer digital media stereo head unit
- Pinoeer 6 ½" Speakers in rear walls
- Rockford Fosgate 4" speakers in front dash
- New Crank pulley / harmonic balancer with new accessory belt
- Front grill with Mercedes logo.
- New windshield with surface rust repair around windshield - Nov 2018
Fluid Changes in Summer of 2018:
- Oil Change
- Transmission Fluid change with filter - Includes transmission dipstick.
- Rear Differential fluid change
Camper Conversion:
Sleeps 4, possibly 5. Seating for 5. Retains factory seat mounting brackets so can remove the seat or change to the 2-seat bench. One full size bed AND two twin beds, OR 2 full size beds.
- Sliding bedside cabinets
- Under-bed storage, both front and rear
- 200W Renogy Solar kit with 20A MPPT Renogy Charge Controller and 200AH 12V Renogy AGM battery
- Maxxair roof vent fan
- All LED lighting - 6 ceiling mounted "can lights" on dimmable switch
- Electrical system installed with master cut-off switches, 40amp circuit breakers, and 14 AWG marine-grade wire.
- Blue Sea Systems Automatic Charging Relay (ACR) to charge house battery from engine alternator
- Natural wood walls
- Replace rear windows with Motion Windows custom fit 1/2-slider windows with screens
- Polyiso Insulation with expanding foam insulation in walls and ceiling
- Sound mat insulation on metal panels
- Reflectix insulation in floor
- Wood grain vinyl plank floor
- Kitchen counter with cabinet storage
- Dometic CFX50W 12V Fridge/Freezer
- Overhead kitchen shelf with integrated LED lighting
- Sprinter factory 3-seat bench
- Mini Dehumidifier
- Table
- Sportscraft heavy duty seat swivels for front drivers and passenger seats
- Custom cut Reflectix insulation window covers with magnet attachment
- Custom screen door
- Custom van cover
Spare Parts also included with sale:
- Extra EGR valve with gasket
- Extra Accessory belt tensioner
- Coolant Temp sensor
- Camshaft Sensor
- Crankshaft Sensor
- ECU relay
Asking Price: $27,500 Or Best Offer!
Additional Pictures can be seen here: 2006 Sprinter Passenger For Sale
2006 158" Passenger converted to camper van
kentonius is offline
Old 11-21-2018, 01:32 PM   #2
kentonius
kentonius's Avatar
Default Re: FS: 2006 Passenger 2500 158" Camper Conversion - Wisconsin near Chicago
Feedback? I've noticed for others it is quiet here as well. Might be the season.
Old 11-22-2018, 04:45 PM   #3
vanski
'05 Box Snow Camper
vanski's Avatar
Kent:
I’ll chime in here with my opinions. First off, there are some thoughtful and well put together details in your build and without going into those details please know I’m not bashing your work here. Also, it does seem Sprinter sales are taking longer which is probably due to diesel prices on the rise and an overall tightening in disposable cash spending due to the economy finally slowing. Hey, it’s been a good run. Business cycles typically last 10 years, trough to peak, so this tightening should be expected.
Beyond that, here’s my high level quick and dirty 2 item feedback:
1. Your target buyer is really limited to a family of 4-5. This greatly reduces your overall market of potential buyers. Who else is going to need all that sleeping space? Personally, I’d keep the bunk as is and configure the lower sleeping space into a ‘garage’ with some configurable storage. This will open up your market to the adventure buyer and all their gear storage needs; bikes, skis, climbing gear, kite surfing gear, surf gear, etc, etc. also, keep the garage separate from the living area. This allows separation of a wet area and the ability to sell the security of the garage where these folks keep their thousands of dollars of gear.
2. My opinion is folks don’t like the look of plywood and I’ve seen ‘plywood’ builds sit for sometime. There are some other great wood accents which I feel will still help keep that cozy look you were going for. I’d primer and paint the plywood and keep the other solid wood accents.
vanski is offline
Old 01-24-2019, 10:01 PM   #4
Be_Free
I would like to see more photos. I am lined up to buy another soon but would consider yours. 858 361 4755
Be_Free is offline
Closed Thread
