Old 03-20-2016, 03:04 PM   #11
Default Re: Help... Destroyed our sink
Great info on how to make new countertop.
If you get a chance, would you mind posting a photo looking at the underneath of your new bathroom sink--especially the edge where the sliding door fits and the frame you mentioned (and same bolt attachments?).
Thanks.
Old 03-20-2016, 08:15 PM   #12
Wasaabi
Sprinter Westfalia #133
Wasaabi's Avatar
Default
Thanks so much for the detailed instructions. Would also love to see pics top & bottom. The round shape and resulting added "counter" space sounds perfect. I wasn't sure how easy corian is to work with, having never done it before. Was thinking about this more and possibly trying marine grade plywood with several coats of poly. Might be a nice look with the SS sink and easier to work with.
Old 03-21-2016, 02:03 AM   #13
discus
GA Westy
Default
I will take pictures tomorrow. Corian is easy to work with. Much easier than plywood as far as Im concerned. you can use a jigsaw to cut the rough shape then practice on the piece you will throw away first. Any wood router will cut a nice edge, use a bit that has a bearing at the end and cut with an even slow speed and dont stop until you reach the other end.
Old 03-23-2016, 09:11 AM   #14
Wasaabi
Wasaabi's Avatar
Default
That is encouraging! I don't have a router but I do have a Dremel. Do you think I could work with that, or do I use this as the excuse to get a router?
Old 03-27-2016, 10:00 PM   #15
Replacement sink and cabinet from Reimo (from James Cook Friends German forum:
http://forum.james-cook-freunde.de/v...hp?f=16&t=2537
Back then, seems Westy sink was still available for a price but another thread had folks looking to special order a minimum run of sinks from another source.
Old 04-02-2016, 10:16 AM   #16
discus
GA Westy
Default
Here's the picture under the countertop.
The Following User Says Thank You to discus For This Useful Post:
OldWest (04-02-2016)
Old 04-02-2016, 07:44 PM   #17
Wasaabi
Wasaabi's Avatar
Default
Discus, it looks like you took off the sink and just mounted a flat piece of coriander over the substructure underneath, so that no ridges were needed in the coriander, just the perimeter cut. Is that right?
Old 04-05-2016, 05:19 PM   #18
triple7
My sink is also starting to show hairline cracks, wanted to replace it with a SS triangle/corner sink, but have yet to find one. Maybe from an airplane lavatory? In the meantime, I found this on Amazon:
Ambassador Marine Oval Stainless Steel Sink
http://www.amazon.com/Ambassador-Mar.../dp/B00GZH5CV4
Outside Flange Dimensions 13 1/4in x 10 1/2in, looks like it might fit, but not sure until you make a template.
triple7 is offline   Reply With Quote
Old 04-05-2016, 05:44 PM   #19
Wasaabi
Wasaabi's Avatar
This one looks good: 8 inch round interior SS - Wayfair and a good price. I plan to work on this once we are back east. Can Discus or someone else confirm that all we need to do is take the existing sink off and place the Corian on top cut to the right size, with no ridges underneath?
Old 04-05-2016, 06:13 PM   #20
From looking at Discus' photo and my own Westy sink, looks like you can cut a piece of Corian and glue/adhere to the underlayment subframe. That subframe has the recessed groove for the top of sliding door.
I can see a tiny gap between that subframe and the curved lip of the one-piece sink overlapping and covering the subframe.
The sink is about 19" x 19" so could look for a 20" x 20" piece to cut down. Wouldn't be surprised if kitchen sink cutout leftover piece might work as kitchen sinks can be pretty big (especially farm/country apron ones).
Large tiles are often 20" x 20" but would be hard to cut (although some tile/countertop places could probably do). That would open up more possibilities than woodworking-compatible Corian/solid surfaces.
Weight is probably something to watch as the subframe doesn't look too thick.
Would be nice to have a complete integrated stainless steel sink like the original acrylic one, but would probably cost a lot to make. Same with a stainless steel showerpan.
Look forward to seeing what Wassabi and others do.
