sikwan
06 Tin Can
When the sun is out, my Fan-tastic Vent fan cover would stick to the gasket. I would have to manually force the cover open using the turning knob. It was annoying, so I went to the website and found this...
http://www.sprinter-source.com/forum/showthread.php?t=732
...received my free upgraded gasket and decided to install it today.
Opened the fan cover to check the condition of the fan gasket.
The black polyurethane caulking that sealed the fan to the roof was turning gray and had some small dry cracks.
Ripped off the gasket and I found the silicon adhesive that was left over.
It was a pain to remove. I didn't remove it entirely. I used a razor blade to clean off whatever I could.
Tube of adhesive that came with the gasket.
Old gasket on top.
New gasket on bottom.
You can hardly see it, but the shiny part of the gasket end is actually the silicon liquid soaked into the foam. I wonder how long this is going to last before it dries out completely. I added adhesive through the channel of foam before mounting it.
Old gasket on top.
