alexk243
KulAdventure
So I have been having a weak starting motor for a while, which I had assumed was a battery since I had replaced the starter motor last year. I recently was pulling my jetskis out of the boat launch and I got into a no start situation similar to low battery power (just clicked once). Jumped it with the aux start to no help. So I looked into the engine bay and noticed that the bolt that holds the power cable to the starter motor was missing its bolt and it had worn through the cable connector. I jiggled it a bit, got the van to start and got it home. Now I would like to fix it, but I am wondering if that is just a direct cable to the battery and where could I source a replacement? Does it need to be OEM or can I just get a 0/0 gauge wire and run it straight from the battery?
Also does anyone know off hand that the nut size would be on the starter?
Sorry the picture is kinda blurry, hard to capture it.
