Old 09-19-2019, 12:42 PM   #11
aarpskier
2017 LTV Unity FX
Default Re: fuse to stop co detector alarm
Originally Posted by autostaretx View Post
... which probably means that the switch at least requires 3 wires:
one for the positive feed from the battery
one for the positive feed onward to the CO detector
...and the third going to "ground" (or negative) to allow the "lit red dot" to operate.
---dick
I actually count the switch interruption of the positive lead as one wire. However, your statement as to the ground is certainly true. Which means once again that my memory is not what it used to be. Either:
1) I don't remember hooking up a ground wire; or
2) I didn't hook up a ground wire and mis-remember the light being on.
I will check the next time I am in the coach. In any event, there are plenty of accessible ground wire sources behind the panel to the left of the entrance steps.
aarpskier is offline   Reply With Quote
Old 09-20-2019, 12:39 AM   #12
aarpskier
2017 LTV Unity FX
Originally Posted by aarpskier View Post
... once again ... my memory is not what it used to be. Either:
No red light, so I did not hook up a ground wire. Not needed, however. Up is "on" and green light on detector, an inch away, starts blinking. Down is "off", and solid green light on detector goes off. I guess I decided I didn't need the "Christmas effect!"
