Old 06-24-2019, 04:04 AM   #1
henry9
Default Add additional 12v outlet?
Greetings,
Id like to add an additional 12v/2 USB port outlet above the bed. Mostly to charge iPhones/iPads and run a laptop.
Is it ok to tie into the 12v antenna booster outlet in the AV cabinet? This is fused for 15v, 14 AWG which s/b plenty? Any other better sources to tie into or ideas?
Thanks,
2008 Roadtrek Agile
henry9 is offline   Reply With Quote
Old 07-02-2019, 05:43 AM   #2
Knit
Knit's Avatar
Default Re: Add additional 12v outlet?
You will be fine tapping USB into the antenna circuit. I did this in my 2013 RS for usb charging and for a camera.
Knit is offline   Reply With Quote
