Death by insulation
fredbail
Thanks to all who have responded to previous questions. I intend to report on my project when (if ever) finished. I have now managed to knock out my blinkers and radio (at least). I sprayed foam in the upper cavities around the roof, and tucked batt type insul. around the bottom of the walls, and covered with 1/4 plywood, whick I screwed in place with 1" lath screws. I saw the stuff about the loose blinker thingy, which I will check, but my guess is I sent a screw thru something, which of course I did not check first for, or managed to force apart a connection with the foam. Any other ideas as to my self inpailment appreciated. thanks, Dan B.
sikwan
06 Tin Can
If you knocked out your radio, you probably hit one of the lines that power the cargo/dome lights.
Did you ever check the fuses underneath the steering column?
