Old 08-01-2019, 03:02 PM   #121
rogerball0
UK Spec 2002 LWB 311 CDI
rogerball0's Avatar
Default Re: Fitting double DIN in a T1N.
Cheers Oroskenneth
Yeah its been a bit of a journey, i'm almost there. Just starting to install security into the van now and then after that i shall have yet another go at solving my air in the fuel system problem that's almost a year old & fit my new 5 tonne leaf springs to the back suspension.
Regarding head units i saw this after all the work i did, looks pretty good and uses your own phone, either Apple or Android:
https://www.pioneer-car.eu/uk/products/SPH-10BT
Cheers
rogerball0 is offline   Reply With Quote
The Following User Says Thank You to rogerball0 For This Useful Post:
israndy (08-02-2019)
Old 08-01-2019, 03:11 PM   #122
ECU
ECU's Avatar
Problem with cabinets for tools. You can't get to them.
Throw in a ladder or some wood. Now you can't open a single door. until you unload it all.
2006 118 Tall. 390,000m, Hillsboro, OR.
ECU is offline   Reply With Quote
Old 08-01-2019, 05:37 PM   #123
rogerball0
rogerball0's Avatar
Hi ECU, if you look at the pics you'll see the main cabinets (sides & bulkhead) are all up off the floor, the wheel box cabinets below that store things like batteries, compressor and stuff thats not directly related to work so everything i use daily is accessible.
That was the main reason for making a compartmented cargo area - so everything is organised and to hand. The previous interior came to resemble a burgled house as i would chuck everything in the saddle boxes over the wheel arches and you couldn't find anything as cavenous as they were.
I even have the spare wheel, relavant tools, fluids and service components in the rear most left hand side compartment all to hand - no crawling under the van to get the spare out.
The collaspable ladder sits in its own compartment inside the sliding door along with my goto consumables like, silicones, fasteners, trade-wipes etc.
Plus the right hand (drivers side) only uses the two topper-most overhead cabinets as everything else is empty so theres plenty of redundancy storage-wise.
Now i'm in possession of a set of 5 ton springs i'm confident i can get the van uprated to 3840kg, might need to change the tyres though apparently, i'll have to check.
My 150 bargains bought them from a guy on the FB forum, he never fitted them and they look brand new, I was going to buy some later in the year but seeing as these were less than half the cost and in as-new condition I snapped them up.
Cheers
Old 08-01-2019, 07:12 PM   #124
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Cheers
Roger,
What size and load index are your current tyres?
Keith.
36,000 miles from New
The Following User Says Thank You to Cheyenne For This Useful Post:
rogerball0 (08-01-2019)
Old 08-01-2019, 08:37 PM   #125
rogerball0
rogerball0's Avatar
Hi Keith
The tyres are Sailun Commercio VX1 they're 225 70 15 & the load index is 112/110 so thats 1120/1060KG
http://www.sailuntyre.eu/PLT/VX1.html
Roger
Old 08-02-2019, 08:17 AM   #126
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Hi Keith
Roger
Roger,
That gives you a max rear axle load of 2,240 kg so IMO good for an increase in GVW to at least 3,800 kg
I have Continental 225/70 R15 112/110 and am plated at 3,800 kg from original conversion to a MH.
Talk to SV Tech http://www.svtech.co.uk/ about what they thinks need doing to uprate your GVW, they are specialists in this field.
Keith.
Old 08-02-2019, 09:35 AM   #127
rogerball0
rogerball0's Avatar
Cheers Keith
I came across that company whilst researching the topic, i'll give them shout.
Roger
Old 08-03-2019, 12:35 PM   #128
rogerball0
rogerball0's Avatar
This is where i keep the ladders:
Roger
