Go Back   Sprinter-Forum > Sprinter-Based RV's & Conversions > Sprinter-Based RV Brands > Forest River
Reply
Old 01-16-2018, 05:18 PM   #1
Rookie0001
Default Towing a toad
I have a 2016 Forester on a M/B 3500 chassis. Getting tired of renting cars when we stay for extended times. I'm thinking of attaching a rig and dragging a small toad ( not a Smart Car, but not much bigger). Wondering what it will do to overall mileage and if it's worth the wear and tear on the main chassis and components. It's just a 24' unit. Anyone have any thoughts and comments? Appreciate it. C'mon springtime......
Rookie0001 is offline   Reply With Quote
Old 01-16-2018, 11:28 PM   #2
Mike DZ
2016 View (2015 3500)
Default Re: Towing a toad
Chevy Sonic LT hatchback automatic trans - 2700 lbs - towed four down - prob 2 MPG - worth it to me.
Mike DZ is online now   Reply With Quote
The Following User Says Thank You to Mike DZ For This Useful Post:
Rookie0001 (01-30-2018)
Old 01-24-2018, 05:03 PM   #3
High Desert
We tow a Jeep Wrangler (2 Dr) with our 2017 FR 2400R. Does great, no issues. really don't see a "wear and tear" issue on chassis and components at it is a direct attach to the frame via the hitch. If I did not see the rig behind the MH, in the camera, would not know it was back there! The Jeep is about 4500 pounds, loaded, and mileage drop is maybe 2 - 3 mpg. Initially we were not getting a toad, but after a few trips and breaking camp and resetting (even though it was easy) decided that a toad was a better option for us. No regrets.
High Desert is offline   Reply With Quote
The Following User Says Thank You to High Desert For This Useful Post:
Old 01-24-2018, 07:25 PM   #4
Rock Doc
Although you’ll likely get several replies here, it will still behoove you to do a Forum search on this topic. It’s been addressed far more than multiple times, and you’ll get a much broader spectrum of opinions than from just this one thread that you can use to inform any decisions you make.
Rock Doc
2014 Pleasureway Plateau TS on 2013 3500 chassis, occasionally flat-towing a 4700 lb. modified 2012 Jeep JK 2-dr
Rock Doc is offline   Reply With Quote
The Following User Says Thank You to Rock Doc For This Useful Post:
Old 01-24-2018, 08:37 PM   #5
hoosierrun
We tow a Toyota RAV4 (modified for towing 4 down). The base vehicle weight is 3750#. With an LTV motorhome on the Sprinter 3500 Chassis the setup does good with about 2 MPG penalty (less at lower speeds, more on the Interstates at 70+). Up steep mountain grades, we do loose a little speed because of the limited top end RPM's, but it really isn't that bad. When the Mercedes diesel works like it should, it is amazingly efficient. Towing takes a while to get used to (like not being able to back up) and it is expensive to set up. Don't skimp on the safety items like a braking system. The 3500 is not like a big diesel pusher and you need the help of the toad brakes to help you stop in a reasonable distance. Tons of discussion elsewhere.
2016 Leisure Travel Vans, Serenity
hoosierrun is offline   Reply With Quote
The Following User Says Thank You to hoosierrun For This Useful Post:
Reply
