N
Nomad_Elvis
Guest
...I have been looking for sheets of the expanded PVC that you used for your cabinets. I am unable to find a 4'x8' sheet for less than $100. Is this the price that I should be expecting? Do you sell these yourself or have a discounted source for them?
1/2 in. thick, 48 in. x 96 in, White PVC foam core exterior trim board
This foamed-core ("cellular") PVC board is denser and stronger than Celtec sign board, and is an excellent substitute for plywood, OSB or MDF.
$56.98 for 1/2" x 4' x 8' sheet at most Home Depot stores.
$13.45 for 1/4" x 2' x 4' sheet at most Home Depot stores.
Currently stocked brand at Home Depot is not the "Veranda" brand but it is smooth on both sides, unlike the photo shown online.
Most Home Depot stores also stock 1/4" & 3/4" thick, and 24 in. x 48 in. sheets and other (long board) sizes, but not all sizes are listed online.
FRP is an excellent alternative for thinner sheets,
and is also available in different textures, including smooth on both sides.
All of these are also available in colors, but local home improvement stores rarely stock anything but white.
Some versions of PVC & FRP sheets are available with a "Class A" fire resistance rating,
but most foamed plastic boards, including Celtec sign board, have not been rated to pass FMVSS 302.
