Old 12-11-2019, 04:47 AM   #1
MorrieC
Default Braking system for Toad
We are setting a Jeep Wrangler JL 2 door to use from time to time as a toad. What braking system are you using for those that tow. The leading candidates are the Roadmaster InvisiBrake or the Demco Stay-N-Play Duo, both of these systems are hardware and installed. The one portable system that looks interesting is the RViBrake System 3 it appears to be quite easy to use.
My question is which one should I go with. I'm leaning toward the Stay-n-Play Duo or the RVibrake System which appears easy to use. I want a reliable system that works. Please let me know if you have any suggestions.
MorrieC is offline   Reply With Quote
Old 12-11-2019, 06:40 AM   #2
Rock Doc
Default Re: Braking system for Toad
I have an RVi system that works well for my towing my 2-dr JK (rather modified with 37” tires and more...). I’m towing this with my Class B Pleasureway, and I’m right at GCVWR as I drive down the highway. I think there are more factors going into which system one chooses than just a "Mikey likes it". I suspect all the available braking systems work well, and overall the pricing of all of them isn’t all that different. With that, the choices are whether you want a permanently mounted system that has the least amount of effort to connect, or a portable system that can be easily swapped between vehicles.
The only other system I can comment on is my experience with an M&G system I had in my Durango 13 years ago—and towed it behind a 38' diesel pusher. That system connected the motorhome's air brakes to a cylinder between the power brake vacuum booster and the master cylinder on the Durango. The Durango brakes were pretty mushy and less assertive until I removed that cylinder. I liked the ease of connecting the brakes, but didn’t like the way it made the Durango's brakes feel. I’m happier with the RVi system I now have, but others on this forum do have different preferences and have different priorities.
Hope this helps!
Rock Doc
2014 Pleasureway Plateau TS in 2013 Sprinter 3500
Rock Doc is offline   Reply With Quote
The Following User Says Thank You to Rock Doc For This Useful Post:
MorrieC (12-12-2019)
Old 12-11-2019, 07:27 AM   #3
Peter Tourin
2012 LTV Unity MB
Peter Tourin's Avatar
We've been using an RVIBrake II for about 4 years. We power it from the car accessory 12v plug - haven't had any problems with draining the car battery. We had extra towing bulbs mounted in the taillights. It takes me about 5 minutes to hook up the car (Blue Ox tow bar) and set up the brake system, and about 3 minutes to unhook.
Peter Tourin
2012 Leisure Travel Unity MB
Peter Tourin is offline   Reply With Quote
The Following User Says Thank You to Peter Tourin For This Useful Post:
Old 12-11-2019, 12:42 PM   #4
jjocean
Since space is a premium I couldn’t figure out what I’d do with a portable unit when I drove the Toad. Went with Demco Stay-in-Play with a charge line from the coach. Couldn’t be happier. The control box (vacuum pump/compressor) had to go under the driver’s seat as the JL Jeep had no room under the hood. It was worth the trouble of the install to have one less thing to move around.
2019 Unity FX
jjocean is online now   Reply With Quote
The Following User Says Thank You to jjocean For This Useful Post:
Old 12-11-2019, 02:30 PM   #5
MWarren
2015.5 Unity CB
MWarren's Avatar
We have a 2015.5 Leisure Travel Unity towing a 2018 Jeep Wrangler JL and been using the Ready Brute Elite for 18 months with the Roadmaster baseplate. Very quick to connect.
https://www.readybrake.com/index.html
MWarren is offline   Reply With Quote
The Following User Says Thank You to MWarren For This Useful Post:
Old 12-11-2019, 03:41 PM   #6
C21bill
2018 Unity TB
I had an InvisiBrake installed in our Fiat Abarth. My regular hitch guy recommended the Stay-n-play over the InvisiBrake because he felt the Stay-n-play was the more reliable unit. I wound up using Camping World to install my tow gear because I caught their $59 installation sale which saved me about $1400. Camping World recommend the InvisiBrake primarily because the control module would be located inside the car (under the driver seat) instead of the hot engine compartment, which is the case with the Stay-n-play. Now, with over 2400 miles of pulling the towd, I am very pleased with the performance of the Invisi-Brake.
C21bill is offline   Reply With Quote
The Following User Says Thank You to C21bill For This Useful Post:
MorrieC (12-20-2019)
Old 12-11-2019, 03:47 PM   #7
kj4oll
2017 24G
We have the RVI-3, works great, easy to install. All the rest of our towing equipment is Roadmaster, but when I looked at the installation and operation of the Roadmaster Invisibrake brake system, seemed like it was a “Rube Goldberg” contraption, and in our 2017 Honda HR-V, would have been very difficult for me to install.
kj4oll is offline   Reply With Quote
The Following User Says Thank You to kj4oll For This Useful Post:
Old 12-11-2019, 06:10 PM   #8
Shallow Water Sailor
2018 Unity MB
We have used the Roadmaster invisi-brake on our 2006 Saturn for 4 years. It works great, no muss, no fuss. Camping World installed it and I would never have them work on my vehicle again. One reason was their $59 install fee morphed into over $200.
Shallow Water Sailor is offline   Reply With Quote
Old 12-11-2019, 06:19 PM   #9
C21bill
2018 Unity TB
Bummer, in my case they provided an itemized quote and charged me the exact amount quoted.
Old 12-11-2019, 07:38 PM   #10
CB1945
CB1945's Avatar
I have a BlueOx Patriot that Iíve used on three different toads and two motor homes. It does not require any mods to the toad other than running the wire from the break a way switch on the base Plate into the car and plug into the patriot.
It does require a 12V power source by plugging into a Live, with the IGN in Acc Mode, Aux Plugin.
It is easy to set up and remove. Can be moved from one vehicle to another easily.
It is a fully proportional brake and performs as advertised. It has a wireless remote dash mounted control that allows the driver to monitor when it is active, control the sensitivity and manually operate the brake if the need arose.
Back years ago when i bought the first one, there were a few cons but BlueOx stepped up and provided a new updated version after I had used it for a couple of years, for 1/3 the cost of a new one.
The new version, and there has been upgrades since then, performs flawlessly. If I were in the market for a new system I would most certainly look at the BlueOx Patriot.
I have no financial interest in the company. I just think they build a good product.
2019 24CB Unity being pushed by a 2013 Honda CRV through a Blueox Aventa tow bar and a Patriot Braking System.
CB1945 is offline   Reply With Quote
The Following User Says Thank You to CB1945 For This Useful Post:
