Old 01-19-2008, 09:14 PM   #1
BW999
BW999's Avatar
Default Constant RPM option, High Idle, I want this
http://sprinter-source.com/forum/att...5&d=1176481343
Bo
BW999 is offline   Reply With Quote
Old 01-20-2008, 02:04 PM   #2
auburnbuilder
Default Re: Constant RPM option, High Idle, I want this
I did this to my van and it works very well. Dealership charged about $45 to program the feature. It is fairly easy to do. Van goes to 2000 rpm when activated. Van must be in park with parking brake set also to work. Parts for this are not very expensive either.
auburnbuilder is offline   Reply With Quote
Old 01-20-2008, 07:50 PM   #3
cheesey1
2004 LT "Free Spirit"
Can you retrofit this feature option in an 04 Sprinter???? I would love to be able to have this feature.
cheesey1 is offline   Reply With Quote
Old 01-20-2008, 11:29 PM   #4
unimog
unimog's Avatar
I have programmable speed control on an 08 sprinter. It works very well and you can set engine speed to any RPM. Handbrake has to be engaged for it to work
unimog is offline   Reply With Quote
Old 01-21-2008, 05:17 PM   #5
BW999
BW999's Avatar
How/when is it adjustble, I have an 05.
Bo
Old 01-21-2008, 07:55 PM   #6
zigzagguzzi
05 Interstate, N. Fl.
Is this the feature that lets the van idle for long periods of time with no damage to engine? zz
: 05 Interstate, Gainesville, Fl
zigzagguzzi is offline   Reply With Quote
Old 01-22-2008, 05:48 AM   #7
BW999
BW999's Avatar
It's not good to let diesels run @ low idle. The noise is detonation, flame fronts colliding. I'm to install the constant RPM option, High idle.
Old 06-17-2008, 02:04 PM   #8
VanSyncro
VanSyncro's Avatar
The 04-06 models are the same and the high Idle switch is for those models, unfortunately there is only one speed setting, 2000 rpm which is a bit high. I've done the install start to finish including the programming. The 08 model is a completely different beast, which sounds pretty cool if you can interactively change speed.
VanSyncro is offline   Reply With Quote
