Well... I'm glad that's over... Researching 'which insulation is best' for a campervan has to be one of the most annoying things we have ever done. There are so many opinions and everybody thinks their way is the best. Well, we have determined that 'The best insulation for a campervan...is insulation is already installed...'
Full Blog Post:
https://adventureinabackpack.com/how-to-insulate-a-campervan/
Video:
https://youtu.be/_GunFIk5vtk
Honestly, we HATED reading through all of the forums, message boards, and facebook groups talking about all of the different tactics for insulating a van because there didn't seem to be much agreement as what the best practice was. Rigid foam, expanding foam, Thinuslate, spray on foam, demin, fiberglass, blah, blah, blah...
It's way too easy to get analysis paralysis when talking about insulation and we are glad that we just picked the one we felt was the best for our case and was in line with our budget.
We chose to insulate (over our sound dampener, of course) with polyiso rigid foam board and expanding foam.
Honestly, the whole process is relatively straightforward. It's just putting insulation into the cavities and securing in place with spray adhesive and (great stuff) expanding foam. We used a mixture of 1" and 1/2" rigid foam board insulation.
Even though the process was pretty straightforward, it was incredibly tedious.
The roof was the easiest with a bit of bracing. The most time consuming were the little small pockets which Steph was able to get her hand, and 1,000,000 pieces of 5"x5" foam in.
The ribs were LIGHTLY filled with the expanding foam. The key is LIGHTLY so it does not over expand and warp the metal and so it dries properly.
The only insulation on the floor is 1/2" foam board. Ideally, we may have used more, but I am 6' 2'' and an extra inch on the floor would take away too much headroom for myself. Gotta pick your battles on that one...
Now that it's done, can we say that the method was the best/easiest/most effective? Well, no... but it is done and should be adequate for our purposes, and that is good enough for us!
