Old 12-04-2018, 09:17 PM   #1
Davydd
Davydd's Avatar
Default Advanced RV lifts 2WD 3.5" same as 4x4
Another Innovation from Advanced RV. They lift a 2WD Sprinter the same as a 4x4ís 3-1/2Ē without the cost of a 4x4 drive. They are using all Mercedes Benz parts. If you donít need 4x4 you get the clearance benefits, save 300 lbs. and get the fuel efficiency of a 2WD. I don't need 4x4 but could use the lift.
Old 12-04-2018, 09:58 PM   #2
OrioN
2008 2500 170" EXT
OrioN's Avatar
Default Re: Advanced RV lifts 2WD 3.5" same as 4x4
Camping at Walmarts just got easier!!
Old 12-05-2018, 09:30 PM   #3
Davydd
Davydd's Avatar
They said they could do retrofits on older NCV3 Sprinters.
Old 12-05-2018, 10:20 PM   #4
Old Crows
Calypso 2014 View Profile
Old Crows's Avatar
Explain please..... how does 'lifting' reduce the weight by 300#. An inquiring Crow wants to know.... (ouuu… that rhymes...) Sorry.
If your 2x2 weighs xxxxx lbs and you add the gear to lift it. It's going to weigh xxxxx lbs PLUS the weight of the add on lift gear. It doesn't suddenly 'loose' 300#.....
The oblique reference is to the weight difference between a 2 by and a 4 by. That makes sense. But your 2 by is going to still increase in weight due to the add on stuff.
Old 12-05-2018, 11:49 PM   #5
Davydd
Davydd's Avatar
Same lift as a 4x4 but 300 lbs. lighter than a 4x4.
Old 12-06-2018, 01:38 AM   #6
GlennR
I wonder if I can lower my 4x4? It seems a lot higher than I'll ever need.
GlennR is offline   Reply With Quote
