Old 06-28-2014, 03:40 PM   #111
sailquik
sailquik's Avatar
Default Re: Living With My New Advanced RV
Davydd,
Yes, the wheels in your photos are the std. MB Silver 3500 5.5Jx16 516/519 (3500 in the USA) series wheels.
As far as rotating the tires correctly using 4 alloy wheels and 2 steel wheels, yes they have to be dismounted and
remounted to stay with the MB recommended rotation schedule.
The reason you cannot just put 6 or 7 Alcoa Alloy wheels on a Sprinter and then rotate them normally is that the
hub centric lugs on the end of the full floater axle, and the rear wheel studs are too short to accommodate the
thicker hub web of a stacked pair of the Alcoa wheels.
The stamped steel OEM 5.5Jx16 MB 516/519 series (3500 USA) are thinner and can be stacked/paired and still
engage the hub centric register diameter on the ends of the rear axle, and also have a few threads showing outside
the lug nuts on the 6 wheel mounting studs.
Hope this helps,
Davydd (06-28-2014)
Old 06-28-2014, 04:08 PM   #112
Davydd
Davydd's Avatar
I guess aluminum alloy is out. Imagine the cost for a tire rotation. I now have Michelins from Discount Tire and they give life of the tire free rotation. I wonder if they would do so if they had to remount tires? I got very frustrated with the nearest Freightliner dealer. They said they couldn't rotate tires on a Sprinter that was clearly indicated on the M-B service schedule. I didn't argue with them as I had the Discount Tire deal. So my last service was at a new Mercedes Benz dealer in Rochester, MN 100 miles away. Not too much of a problem since it is on our frequent route down to La Crosse, WI and we could just hang around for a couple of hours with a Target, Dick's and Lowes next door.
Old 06-28-2014, 05:27 PM   #113
bobojay
David, just for curiosity, how's the service prices at MB Rochester compared to your Freightliner dealer close by?
Sprinter Owner
2013 Winnebago ERA 70A
Class B Van (2013 3500 chassis)
bobojay is offline   Reply With Quote
Old 06-28-2014, 10:39 PM   #114
Davydd
Davydd's Avatar
Unfortunately it was more expensive but they were also way more thorough, explained all their services, washed the van and even cleaned the inside of the windshield, and served free coffee and powerbars. :)
BTW, the Freightliner dealer is not exactly close. They are 40 miles away on the same highway we take to Rochester. We have a Mercedes Benz dealer about 8-10 miles away that has a subsidiary that sells Pleasure-way Class Bs. Ironically, after two years doing that they still don't service Sprinters. A Sprinter service for a Mercedes Benz dealer is supposedly a million dollar investment said the M-B rep at Advanced Fest.
Old 06-29-2014, 04:58 AM   #115
bobojay
I wish the MB Sprinter dealer here in Kansas City was that thorough. Feels like a regular Chevy or Ford dealer in their waiting room. No extras....
Sprinter Owner
Old 12-05-2014, 05:25 PM   #116
Unity Traveler
2013 LTV Unity Twin Bed
Originally Posted by Diamondsea View Post
I have 4700 miles on the rig. A couple of days ago I drove down a very steep private drive and upon startup to leave a check DEF message came on. From my readings on this forum I thought that was premature mileage wise. I decided that the sensor in the DEF tank might have been left "exposed" above the fluid level due to the extreme grade. Anyway at my next fuel stop at a typical 7-eleven type gas station that sold diesel fuel I asked if they sold DEF. Sure enough I was surprised that they did near the motor oil and it was just over $6/gallon. It was branded "PEAK" which is a name I am familiar with for products like washer fluid. It was labeled "Blue DEF" although it was clear, not dyed. The gallon jug had no special spout or opening but I was able to pour it in carefully without spilling a drop. Upon startup I continued to get the check message, but the message did not appear after the next startup and it has not returned.
I guess I will never know if the level was really down or if the very steep grade had fooled the tank sensor. My driving is mostly highways with little stop and go city type driving. I was thus surprised to add the fluid at 4700 miles so I tend to believe that the steep grade fooled the system. Does very cold weather use more DEF?
We have replaced our Def Fluid three times & each time the mileage was approximately at the 4500 mile level. Seems to be the norm for us.
2013 LTV Unity TB Sprinter 3500
Diesel Generator 3.2 KW
Equalizer Automatic Level Systems
Entertainment Center
Macerator
Side Turn Cameras
Unity Traveler is offline   Reply With Quote
Old 12-05-2014, 06:13 PM   #117
hein
Van Guru
I am a dedicated Discount Tire customer. The manager at my store said they would be happy to dismount the tires to rotate them. I probably won't rotate my MS/2s although I might rotate the spare through front wheels if that's an acceptable practice.
Flying J truck stops are an easy place to get DEF at the pump, BTW. I'm sure others have it also.
2010 MB 3500 RV conversion.
Old 12-05-2014, 07:14 PM   #118
Davydd
Davydd's Avatar
You can get DEF fluid at almost any auto store like NAPA, Advanced, O'Reilly, etc. and just about all truck stops. Sometimes you can at regular service stations but only likely if they also sell diesel. When the light comes on you have plenty of time to find a store.
