Old 04-30-2019, 03:55 PM   #1
Civrel
Default Body Style Info for Sprinter 3500?
I was looking for an oil filter and found reference to several body codes, Body code 906.155, Body code 906.657, Body code 906.153, Body code 906.655 and Body code 906.653.
I have searches all the decals and plates I could find, but none referenced or contained any of the number sequences above. Also, I ran a VIN check and found that my 2018 Four Winds 24SF chassis was manufactured in 2016. Would this mean I need to search for chassis parts for a 2016 or 2018?
Sorry, new to Sprinters.
Civrel is offline   Reply With Quote
Old 04-30-2019, 08:30 PM   #2
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Default Re: Body Style Info for Sprinter 3500?
Hi,
You are correct, you should be looking for parts for a 2016 chassis.
If you enter your VIN here https://www.datamb.com/ you will see there are two VIN's for your Sprinter. The typical USA VIN and also a European VIN. In this second VIN look for the numbers 906 and then the next three numbers will be your model type.
Keith.
36,000 miles from New
Civrel (04-30-2019)
Old 05-01-2019, 09:35 AM   #3
kylecm
I have a 2014 Thor built on a 2013 Chassis. Yes all of your chassis parts will be for the MB Sprinter 3500 Chassis.
In regards to the body code, Thor Support maybe able to help, but your local Mercedes Benz Sprinter Service facility can absolutely help. In my case it has never really mattered about the body code since the chassis and front passenger compact is all the is left from my Sprinter.
Funny note, MB thinks I have a white standard, no side window 3500 :-)
Hope this helps
Chuck
kylecm is offline   Reply With Quote
