Go Back   Sprinter-Forum > General Forums > Sprinter Talk > Scanners
Old 12-15-2015, 12:40 AM   #11
rlg999
2005 3500 Long/Hi Camper
Default Re: iCarsoft MBII diagnostic tool review
Here's a few more pics.
rlg999 is offline   Reply With Quote
The Following User Says Thank You to rlg999 For This Useful Post:
brassarl (01-19-2016)
Old 03-01-2016, 02:19 AM   #12
BenJohnson
2006 2500 T1N
I just got my MB-II scanner today. For a sprinter scanner this is great. Easy to use, can check and clear fault codes on a bunch of the subsystems, and can see live values on a number of the subsystems - its a winner!
BenJohnson is offline   Reply With Quote
The Following 4 Users Say Thank You to BenJohnson For This Useful Post:
Aqua Puttana (03-02-2016), Frank Mc (08-04-2017), Gulf SV (06-27-2018), long1pham (12-24-2016)
Old 03-01-2016, 10:18 AM   #13
Arnie_Oli
Does this kit have the ability to code to add an auto cruise addon or is it limited to trouble codes and data readouts?
Arnie_Oli is offline   Reply With Quote
Old 03-02-2016, 06:29 PM   #14
BenJohnson
2006 2500 T1N
Just trouble codes, reset codes, live data and freeze frame.
No features to trigger door locks, reset adaptive shifts, set steering angle, etc.
The Following User Says Thank You to BenJohnson For This Useful Post:
SprintKon (06-19-2018)
Old 03-10-2016, 07:02 PM   #15
srmpf
interesting - the device shows the transmission temperature. Means that there is a temp sensor in there and since its ODBII, you should be able to read it with the scangauge.
srmpf is offline   Reply With Quote
Old 03-10-2016, 07:26 PM   #16
BenJohnson
2006 2500 T1N
Yes there is a temp sensor in the tranny, but the TCU is *not* OBD. It is K-line. Your scanner must be able to read sprinter mercedes specific sub-computers. A generic OBD reader will not do it.
Old 03-16-2016, 10:32 PM   #17
srmpf
got mine in the mail today. bummer, doesn't read ABS specific codes (which my Autel does)
Old 03-17-2016, 07:39 PM   #18
compostbrain
it seems you can only get data stream in the transmission module. So no rail pressure or anything related is available. Is this what others have found?
compostbrain is offline   Reply With Quote
Old 03-17-2016, 11:16 PM   #19
BenJohnson
2006 2500 T1N
Yeah, I have the same. It cannot read codes from ABS - bummer. They have on their website "BS/AIRBAG:Diagnoses ABS/ SRS system codes, Reads/clears codes of ABS/SRS system and turns off ABS/SRS warning light, Performs bi-directional tests such as cycling the ABS solenoids, Retrieves ABS/SRS ECU information etc." I will be sending them an email note, please do the same. DONT MENTION DODGE. They got all twisted when I told them I had a dodge sprinter when I was inquiring about config files.
As for live data, yes it can read a numer of subsystems, Here are the ones I am getting:
* Common Rail Diesel Injection
* Electronic Selector Lever
* Electronic Transmission Control
* Heating Control
* Electronic Stability Program
Are you sure you are using the right configuration? Sprinter -> V11.20 -> 901.6... -> Diesel Engine
Old 03-18-2016, 04:07 PM   #20
compostbrain
I am using the same configuration but i don't get an option for data stream in anything except the tranny module. Did you have to run a software update or anything?
