sprint2freedom
2008 NCV3 170ext
Just reread your earlier post- do you have multiple fobs with this issue?Interesting, how would I go about determining this?
The only change I made to the van was adding an FM bluetooth transmitter so I can stream music from my phone, this plugs into the lower 12v outlet below the radio..
thanks
If so, that sounds like a van-side antenna problem rather than fob-side. For example, accidentally severing, moving or grounding the antenna wire for the keyless entry might cause this type of behavior.
Or if it's not a coincidence, perhaps your bluetooth transmitter is causing interference. Have you tried unplugging it and testing the fob again?
