Old 07-22-2019, 01:31 AM   #11
autostaretx's Avatar
Default Re: Coach charging solenoid
Originally Posted by RV2019 View Post
Does this mean the solenoid has intermittent issues?
Quite possibly ... or the circuit that's driving the small wire.
The loss of a tenth of a volt across the relay "feels" a little high, but i don't have comparisons to base that on.
Old 07-22-2019, 01:36 AM   #12
RV2019
2017 Wonder MB
It has all been working well this trip (25 days).
I’ll have to start monitoring the VictronConnect app during our travels I guess.
Any other suggestions?
RV2019 is online now   Reply With Quote
Old 07-22-2019, 10:34 AM   #13
mikeme
2015 LTV IB: 2015 3500 V6
Did you have the battery at a very low level of charge?
one additional component in the system is an isolation delay relay,
https://pdxrvwholesale.com/products/...y-00-00629-120
this device inserts a delay after sensing that the engine voltage indicates that the engine is charging the starting battery enough to also provide more current to charge the house battery.
If the house battery was very much discharged, it could be that as soon as the house battery was connected, it dropped the voltage so far it cut out the relay.
If it was me, I would keep an eye on it.
Mike
"Free advice is worth what you pay for it. Sometimes.."
mikeme is offline   Reply With Quote
Old 07-22-2019, 11:01 AM   #14
SSTraveler
2014 LTV Unity Murphy Bed
SSTraveler's Avatar
My last long trip I realized my Isolator Solenoid (IS) wasn't working. I watched my Victron BMV-712 and noticed that the IS was only working intermittently. So I am replacing it with the Blue Sea ML-ACR a solid state more reliable unit. Here are some posts that may be helpful, https://sprinter-source.com/forum/sh...light=Blue+sea and https://sprinter-source.com/forum/sh...light=Blue+sea. It's an easy swap out once you find your IS and Isolator relay, if your Wonder is anything like the Unity (both under passenger seat).
SSTraveler
2014 Unity Murphy Bed/2014 MB Chassis
SSTraveler is online now   Reply With Quote
The Following User Says Thank You to SSTraveler For This Useful Post:
Danarbor (07-22-2019)
Old 07-22-2019, 11:55 AM   #15
hoosierrun
The voltage on the large terminals match engine (12.8) and house (13.3) voltages with engine off.
Small wire is 0.
Engine on
Engine battery 14.32
House battery 14.48
Small wire 14.36
Now Iím lost. Seems solenoid is working.
Just started engine again and according to my VictronConnect smart bmv it shows charging at 27.9 amps 14.11 volts and 95% SOC. I had run the generator for about and hour and a half to charge batteries after we stopped.
Running 2 6 volt agm batteries. Originals were 12v flooded.
It might. With dirty grayed contacts it could connect up sometimes but not other times. That is the way mine acted. It will only get worst if that is your problem.
2016 Leisure Travel Vans, Serenity
hoosierrun is offline   Reply With Quote
