Hi Gulf
"f you're going to put in a house battery, you should be more concerned about getting under the passenger seat. Lots more room for a battery. "
It came with one under the drivers seat which is dying.
Hi Glass,
"A starting battery isn't designed for use as an auxiliary battery to power lights, etc., unless you plan to never deep cycle it. Look for a true deep cycle battery, although they're probably not easy to find in a Group 49 size. A group 49 Deka AGM may be a reasonable choice."
I know you are correct,but it came from the factory with a starting battery.
VW does the same thing. But it lasted 7 years with many,many plunges to full discharge.When I went to replace it,the battery guy told me to stick with the same.....it was cheaper than a deep cycle,and had a much longer warranty
Hi Glass,
