There is so much confusion about bio/biomass diesel. I saw this post on the Minnie Winnie’s forum. I think Chevron’s reply should clear up some of this.
‘I have a question regarding the diesel fuel from your Chevron stations. The pump has a green label stating "Ultra Low Sulfur Highway Diesel 15ppm sulfur maximum" The pump also has a black and orange label stating "Biomass-Based Diesel Blend" in quantities between 5 and 20%. My Mercedes dealer states this fuel will void my warranty. Mercedes states; Most fuel stations in the marketplace sport a blend of diesel fuel and biodiesel, the ‘bio’ being derived from a plant base or recycled oil. Mercedes-Benz requires owners to use diesel with less than 5 per cent biodiesel, called B5. The problem is that many outlets throughout the U.S. offer diesel with up to 20 percent biodiesel - B20. This higher level wreaks havoc on the engine, leading to expensive issues not covered by warranties because people have used the wrong fuel. “Continuous use of B20 fuel can lead to fuel filter clogging and injector deposits, and can cause the engine oil level to rise due to unburned fuel washing into the oil pan. A clogged fuel filter as well as injector deposits can cause engine performance degradation while increased engine oil levels due to dilution by unburned fuel can cause engine mechanical damage.” That’s right from a Mercedes pamphlet. So do I avoid all Chevron stations? According to the black and orange label your fuel is not meeting Mercedes Requirements. I am looking forward to Chevron's technical advice.
Reply;
Thank you for the inquiry.
To address your primary concern, we would like to inform you that Chevron diesel fuel may contain up to, but no more than 5% biodiesel.
The wording on the orange label you are referring to “contains biomass-based diesel or biodiesel in quantities between 5 percent and 20 percent” is required by the FTC, and serves to notify the customer that the diesel fuel contains biomass-based diesel (in addition to petroleum-based), but does not necessarily mean it is a biodiesel product.
Biomass-based diesel, also known as renewable diesel, is a hydrocarbon diesel vehicle fuel produced from non-petroleum renewable resources. Renewable diesel is virtually indistinguishable from conventional (petroleum-based) diesel fuel in its chemical composition and performance. Accordingly, renewable diesel is considered a “drop-in” fuel, which means it can be used in blends with conventional diesel fuel, and its presence will be transparent to vehicles or equipment. Chevron diesel fuel with renewable diesel component meets ASTM D975 requirements (basic requirements all diesel fuel must meet).
Biomass-based diesel does not necessarily mean biodiesel, although it is also bio-derived. Biodiesel is produced from similar renewable feedstocks, but its chemical composition is distinctly different, and it is produced using entirely different chemical processes than those used in making renewable diesel.
All diesel fuel sold in the United States is allowed to contain up to 5% volume biodiesel, and still comply with ASTM D975. Any fuel with greater than 5% biodiesel content will have unique labelling with the letter B followed by the volume % biodiesel, and will be blue colored, rather than orange colored label you referenced (please see the images below, with red circle identifying the label you observed).
To answer your question: all Chevron branded diesel fuel meets or exceeds ASTM D975 requirements, which address the requirements for all diesel engines; there is no need to avoid any Chevron branded diesel fuel because it may contain up to, but no more than 5% biodiesel.
We understand this regulatory required labelling and terminology are confusing to the consumer, so we encourage you to please contact us by phone or email if you have any additional questions.
Regards,
Chevron Fuels Technical Service
fueltek@...
tel: +1 510 242 5357 option#3
office hours: Mon-Fri 9-11am; 1-3pm (Pacific)
