Go Back   Sprinter-Forum > Sprinter-Based RV's & Conversions > Sprinter-Based RV Brands > Leisure Travel Vans > Serenity
Old 04-10-2015, 10:00 PM   #1
bear112
Default Stabilizer jacks
I have stabilizer jacks on my 2012 Serenity which have become quite noisy when extending and retracting them. They are obviously in need of lubrication, but since I can't fit under the vehicle to service them myself, I'm thinking about having the Mercedes dealership do it when it is on the hoist for its next service. Has anyone had this done? What is the recommended lubricant? I can't find any reference to this in the owner's manual. Any help would be appreciated. Thanks.
bear112 is offline   Reply With Quote
Old 04-10-2015, 10:30 PM   #2
chromisdesigns
Default Re: Stabilizer jacks
I would check with them first. Some dealer service departments won't work on anything not installed by Mercedes or a Mercedes service center. Just one of the little joys involved with owning an RV.
2014 Coach House Platinum II
on 2013 Mercedes chassis
Soon to be up for sale due to repeated Mercedes diesel bugs!
If you are still into sprinter rvs and think you might want the nicest possible version send me a PM for details.
chromisdesigns is offline   Reply With Quote
Old 04-10-2015, 11:22 PM   #3
JimDyson
what type of jacks are they, hydraulic?
Jim
JimDyson is offline   Reply With Quote
Old 04-11-2015, 01:33 AM   #4
bear112
I'm not actually sure; there is a rocker switch on my control panel to extend and retract them, and if I forget to retract them before starting the vehicle, they will retract automatically before I can start up.
Old 04-11-2015, 11:30 PM   #5
JimDyson
If you see the Equalizer Systems brand name on the control switch they are probably the StabiLite product found at this link http://equalizersystems.com/rvs/motorized/stabi-lite/
You might either find some service literature on their site or request some information from them.
In general, most people use a lubricant that is dry wax type so as to not attract dirt. but it would be best to double-check what's recommended.
hope this helps...
Jim
Old 04-13-2015, 04:48 PM   #6
Chip D
Chip D, 2013 Serenity
Chip D's Avatar
Yeah, I had the same problem. So just climbed under the rig when the stabilizers were set, and hit the screw with Silicone spray that will handle the water and salt and stuff from the road. It's much easier if you have 2 people. One to hit the retract while you are under the rig squirting the screw. Amazing what a little Silicone lubricant will do. While yer at it, you might as well do the Electric steps too.
Chip D.
Chip D is offline   Reply With Quote
Old 04-15-2015, 09:26 PM   #7
israndy
Custom User Title
israndy's Avatar
If you have a driveway just pull out into the street for a second and you have LOTS of space underneath to do the quick job of lubing the stabilizers. I guess I am assuming you are not on a main drag.
I purchased those plastic squares for lifting the RV so I can get under. The stack of them perfectly fit under the drivers seat in that locker under the fuel flap. Still leaves space as wide as the door to put other things in, I have a shopping basket that exactly fits that part of the locker to make it easy to get to my cords and such that I always have in the RV.
-Randy
T1N 2005 3500 based 2007 Leisure Travel Van's Serenity
Also a 40' Airstream Sky Deck, a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: March 2018 Tesla Model Ƹ, 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles
Old 05-01-2015, 01:32 PM   #8
Denis4x4
2013 Unity TB
Denis4x4's Avatar
Motorcycle chain lube is the best lube. WD-40 will attract dirt.
Denis4x4 is offline   Reply With Quote
Old 12-01-2016, 09:52 PM   #9
Incredulocious
2016 LTV Unity TB
I realize this is an old thread but here's the maintenance recommendation from Equalizer Systems for the Stabi-Lite/Level-Lite systems we have:
From http://equalizersystems.com/wp-conte...Level-Lite.pdf:
Keep the leg assemblies clean. Extend the leg to around mid-point and clean the assembly using a wet rag. A mild detergent such as a car wash solution may be used. If using a spray cleaner such as Simple Green or fantastic do not spray heavily on to the motor gearbox potion. It may be rinsed using low pressure spray from a hose. (Do not use a pressure washer)
It is important that the screw/nut be kept clean and dry. In extreme cases the use of WD-40 or similar may be used to clean the screw/nut the leg assemblies however they then must be completely washed and rinsed and allowed to dry. The use of compressed air may be used to help the drying process.
After cleaning, the pivot points and the screw/nut must be lubricated Lubrication must be done using a dry film Silicon/Teflon Spray lubricant or Boeshield T-9 is the currently recommended lubricant. The use of oily or greasy lubricants is not allowed as they will attract dirt which will create issues with the screw/nut.
And the installation and operation guide is here: http://equalizersystems.com/wp-conte...ion_Manual.pdf
Incredulocious is offline   Reply With Quote
The Following 2 Users Say Thank You to Incredulocious For This Useful Post:
aljimenez (12-02-2016), MSDVLD (12-05-2016)
Old 07-11-2017, 04:58 AM   #10
GAMacky
GAMacky's Avatar
I just have a quick question. I suppose that the stabilizer can't be used as leveling jacks? Wouldn't it make more sense to have automatic leveling jacks instead of these?
GAMacky is offline   Reply With Quote
