Old 12-24-2019, 01:15 PM   #1
tonyhawk
Default Roadtrek Adventurous Alde Upgrade Kit
Hello,
I'm ready to do an Alde system flush. I have heard a few people mention an upgrade kit that was available from roadtrek before the BK. I believe it is some sort of bypass (I have also read that it included an upgraded rear convector with fans - I'm not sure about this since I have a cover over mine). Would anyone be able to point me in the right direction as to where to get these parts/fittings?
Thank you
tonyhawk is offline   Reply With Quote
Old 01-11-2020, 12:43 PM   #2
KathRN
Default Re: Roadtrek Adventurous Alde Upgrade Kit
If you go to their website you can send a message and they do answer.
https://www.alde.us/
Alde Corp
6700 NE 152. Suite 160
Vancouver, WA 98682
Telefon: 360-597-3017
Fax: 360-718-7077
KathRN is offline   Reply With Quote
Old 02-11-2020, 01:41 PM   #3
hdevera
hdevera
The "Upgrade Kit" is rather expensive. You can use a submersible water pump and regular garden hoses, along with a 5 gal bucket. You can use water to flush the system into the bucket. When the draining glycol solution is flushed, you will see the water coming out (change in color). So now water is in the system. Now just flush the water with glycol solution (4.5-5 gallons glycol needed). Water draining into the bucket will turn to whatever color glycol solution you are using (most use a yellow solution). A little time consuming but you only need to do this every other year
hdevera is offline   Reply With Quote
Old 02-25-2020, 11:46 PM   #4
MrB
EHGNA "upgraded" floor heating in some units. It involved changing some of the plumbing/valves to promote better glycol flow through the tubing under the floor. They also added convector fans to some units.
MrB is offline   Reply With Quote
