Old 11-13-2016, 12:53 PM   #1
chiro1973
Default Urgent crankshaft bolt info
So I'm stuck in the Backwoods of Arkansas with a separated harmonic balancer can somebody please tell me which direction the crankshaft bolt comes out is it a lefty Loosey?
Thanks in advance stuck in the woods!
chiro1973 is offline   Reply With Quote
Old 11-13-2016, 12:56 PM   #2
Default Re: Urgent crankshaft bolt info
It is a normal bolt. Counterclockwise to remove. Be aware that the bolt is one time use and that replacement bolts need to be torqued to a High torque value followed by a degree factor which varies depending on which type of key and bolt is used on your vehicle.
In a pinch it might be possible to reuse the bolt a second time but I would replace it promptly upon getting to a location where this was possible.
Old 11-13-2016, 01:09 PM   #3
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
Another possibility is to remove the separated ring and get the proper parts assembled prior to the job.
http://www.sprinter-source.com/forum...265#post495265
Old 11-13-2016, 01:17 PM   #4
chiro1973
Thanks for the quick response I was able to get the harmonic balancer pulley assembly yesterday from two hours away but they did not have the bolt so I'm going to have to reuse the bolt to make it home
Old 11-13-2016, 01:36 PM   #5
chiro1973
Vic, you're not saying it's OK to drive it after the ring is removed are you?
Old 11-13-2016, 01:57 PM   #6
If the outside ring is separated you can remove it, reinstall the serpentine belt, and drive a short distance if needed.
Old 11-13-2016, 02:03 PM   #7
Aqua Puttana
It may be. Go to the thread I gave you.
Old 11-13-2016, 04:02 PM   #8
chiro1973
Thanks I checked out that other thread decided to remove the ring and I'm keeping it below 2000 RPM's and she seems to be fine no vibration whatsoever
The Following User Says Thank You to chiro1973 For This Useful Post:
Aqua Puttana (11-14-2016)
Old 11-14-2016, 05:11 PM   #9
chiro1973
Well I made it the 700 miles home without issue....pheeeew
I can't seem to find anybody that carries the crankshaft bolt and washer. Any help is appreciated.
Old 11-14-2016, 05:28 PM   #10
NateV
2006 T1N 158wb 410k miles
Go to http://europarts-sd.com will have everything you need.
Best prices, excellent service, OEM parts. They specialize in Sprinters.
They ship Fedex so you'll have your parts in the next day or two.
2006 Dodge Sprinter 158 wheelbase 410,000 miles
NateV is offline   Reply With Quote
The Following User Says Thank You to NateV For This Useful Post:
