Using Westfalia A/C unit as fan only
Zach Woods
One little known capability of the Westfalia A/C unit is for it's use as just a fan (ie without the A/C compressor running and cooling the air).
In order to use the A/C unit as just a fan, turn on the A/C using the big illuminated A/C switch in the cieling control panel. Adjust the A/C cooling dial to the lowest setting. Now twist the A/C cooling dial further past a detente that makes it seem that you can not adjust it any lower. This detente distinguishes between compressor on and off settings and will allow you to use the unit as simply a fan to bring fresh outdoor air into the camper.
