Go Back   Sprinter-Forum > VS30 Sprinters > VS30 4x4 Talk
VS30 4x4 Talk General Discussions related to VS30 4x4 Sprinters.
Old 09-30-2019, 08:31 PM   #1
mdbrown
Default Have you installed aftermarket wheels?
I am about to order some Black Rhino wheels in 17x8, with 38mm offset (not the 52mm offset). I think I would rather do that than install wheel spacers. Will probably install BFG ATs in 275 width with either the 65% profile (31.1" dia) or 70% profile (32.2")
Does anyone have experience with these wheels or tire sizes on a 2019 Sprinter 4x4?
I understand these require longer lug bolts, which I have already ordered.
Thank you!
mdbrown is offline   Reply With Quote
Old 09-30-2019, 08:52 PM   #2
grantwilson
FreedomVanGo
grantwilson's Avatar
Default Re: Have you installed aftermarket wheels?
Id do the 65 and you may still need the agile fender trim.
I have 16x8 +25 with 33" and i still need to trim more
2019 144" Pebble Grey 4x4 currently being built. Contact me!
FreedomVanGo - Jacksonville Florida
The ONLY Certified Adventure Wagon dealer and installer in the SouthEast
Authorized Dealer for Dometic, Ripplewear, Tern Overland, Van Compass and more!
www.vangooutdoors.com
www.youtube.com/GrantWilsonFL
www.Instagram.com/FreedomVanGo
grantwilson is offline   Reply With Quote
The Following User Says Thank You to grantwilson For This Useful Post:
mdbrown (09-30-2019)
Old 09-30-2019, 09:09 PM   #3
mdbrown
My plan is to do Van Compass 2" lift when it's available, or maybe some combination of Van Compass lift and Agile coil-overs, if that's possible. So, hoping to limit other mods for clearance until that gets done and i know what, if anything is required.
Old 10-01-2019, 03:00 AM   #4
grantwilson
FreedomVanGo
you need the fender things no matter what if you plan on running 32/33"
Old 10-01-2019, 03:07 AM   #5
sanomechanic
If a Transmission, engine or anything else related to the drive train or suspension components fail on a New Sprinter that has been altered with Over size tires, ect. Wonder if MB will tell you, warranty void.
sanomechanic is offline   Reply With Quote
Old 10-01-2019, 04:04 AM   #6
Patrick walsh
Hmm,
My dealer told me today to bring my van in and they would mount balance and then reprogram my vans electronics or whatever so my active cruise and nav would still work.
For whatever it’s worth that’s what I’m being told. I’m gonna give it crack and see. I have no real reason to doubt them. I was very surprised today when I got the news, and very happy as I’ll loose my mind is I have to run wimpy 30.5’s forever..
Patrick walsh is offline   Reply With Quote
The Following User Says Thank You to Patrick walsh For This Useful Post:
mdbrown (10-01-2019)
Old 10-01-2019, 04:09 AM   #7
DevilSprinter
Let us know how it turns out. I would like to run 33’s.
DevilSprinter is offline   Reply With Quote
Old 10-01-2019, 04:35 AM   #8
mdbrown
just ordered them... agile is pretty proud of those! $350 :)
Old 10-01-2019, 03:07 PM   #9
mdbrown
Originally Posted by Patrick walsh View Post
Hmm,
For whatever itís worth thatís what Iím being told. Iím gonna give it crack and see. I have no real reason to doubt them. I was very surprised today when I got the news, and very happy as Iíll loose my mind is I have to run wimpy 30.5ís forever..
looking forward to hearing your results at the dealer!
Old 10-01-2019, 03:47 PM   #10
sanomechanic
One thing to be careful of with these New Sprinters. If anything fails or has issues from Transmissions to suspension to whatever MB can blame on alterations... Your warranty in that particular area my be voided. If work was performed by dealer then no worries.
Through my 35 plus years working for Toyota, Lexus, Honda and Acura. I have witness many warranty claims denied due to installation of certain aftermarket applications. Including certain over sized and or extreme offset wheel and tire packages.
For instance...Put a lift kit and go 4 sizes up on tires then your wheel bearings start growling, transmission fails or propeller shafts start going bad. Doubt very seriously MB will repair it under warranty
The Following User Says Thank You to sanomechanic For This Useful Post:
Boxster1971 (10-02-2019)
